Question about Microwave Ovens
I've replaced the keypad and computer on my kems378gss3 Kitchenaid microwave oven/oven combo. Everything works EXCEPT that the microwave doesn't actually cook, and the timer set-start button doesn't work. I need the keypad codes to input so the computer will turn on the magnetron. Kitchenaid refuses to give me these. If someone knows these codes for this model and can give me these instructions, I'm happy to pay your fee. I am man of my word! Thanks. I asked this question once - a minute ago - but it disappeared from my screen and I'm not sure it got through. Hoping to hear from you.
  • 2 more comments
  • laurelton Mar 07, 2008
    Original problem: Microwave Display window showed DOOR (and you couldn't enter a time) - even though the door WAS closed. Checked all interlock switches. They checked O.K. While looking I found a hairling crack in the flexible printed circuit board that connects the keypad to the computer. I replaced BOTH as a fail-safe. With new kepad and computer installed, all works perfect EXCEPT for the timer set-start button, and the fact that even though the microwave oven works, it doesn't COOK. When pressing (and holding) 1, the codes are c30 r12 E - - Does this all help YOU to help ME?
    Thanks for the info. I'll take the thing apart later and RECHECK the interlock switches. I'll get back to you later. Stay with me. Thank you!
  • laurelton Mar 09, 2008
    Dear Jaime867 and everyone. FIRST OF ALL.... thank you for your generosity in trying to help. Curiously the problem I was having was caused by by 2 IDENTICAL 4 pin plugs - with identical keyways - that I interchanged when re-assembled the unit. Since they LOOK idenrical it was an easy mistake. It is curious that Kitchenaid would do this. As I was checking and rechecking (with an ohmmeter) I discovered a number of "illogical" conditions which could ONLY be caused by wiring mistakes. Since I did **t alter any of the connections, this made ** sense. I **ticed that the color coding of the wires going to these identical plugs was arraged differently. (The color coding was in the diagram inside the microwave.) Putting the plug back correctly solved the problem. (Replacement of the keppad and computer was still necessary, though I'm lucky the mixing these plugs didn't blow anything up! Thanks again.
  • Jaime Hernandez May 11, 2010
    What was the original problem that made you changed the keypad and computer?
  • 2,326 Answers
I would suggest to check all the connections from the new installed parts and double check your switches.
Have you followed the user guide from page 35 to try to unlock that key?
If still does not work, there may be two possibilties that the new keypad(timer set-start button) may not work or the magnetron is defective.
Check this link as well for some additional info.
Posted on Mar 07, 2008
Everything on microwave works except it doesn't heat or cook. what is the problem?
IT'S THE MAGNITRON - CHEAPER TO BUY NEW THAN REPLACE - SORRY.
Jan 09, 2013 | Microwave Ovens
Litchenaid KEMC377KSS05 says DOOR and microwave wont start
follow the next step and use the common sense: God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Aug 03, 2012 | KitchenAid KBMC140HSS Convection/Microwave...
Buttons not working on keypad of microwave
The keypad control board is defective and must be replaced.
Apr 22, 2012 | LG Kenmore 1.2 cu. ft. Countertop...
Kitchenaid vented microwave KHHS179LSS-5 surface light is blinking on and off. Started a couple of weeks ago. Thought I was forgetting to turn the light off but realized it was not me. Went to the...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Apr 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Everything works except it won't heat up
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 13, 2010 | KitchenAid KCMS145J Microwave Oven
Will not operate. displays f2
F2 means you have a shorted membrane keypad.
On some models, you can get the membrane keypad replaced by a servicer or your can do it yourself, but on some models, you would have to order a new control panel frame which comes with a new keypad.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Apr 25, 2010 | KitchenAid KHMS155L Microwave Oven
My micro wave stop working f-2 is on screen
Possibly a keypad short or motherboard fault if it is a KitchenAid microwave. Beware if you have a KHMS155LSS model, a Keypad short can and will cause the microwave oven to start on its own. A real stunning defect.
Sep 06, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid microwave/oven combo model KEMC308KSSO
The keypad circuit board must be replaced to start. Sometimes, the fault can also be on the main processor board.
Jerry G.
May 15, 2008 | LG LMV2055ST Microwave Oven
I've replaced the computer on my kitchenaid kems378gss3 oven/microwave combo. I need the "codes" to key in on the keypad - to make the microwave actually "cook: things. Everything else works...
If you don't have the owner's manual you can download it here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204452300.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20(Micro)%20-%204452614.pdf
Some units will not allow time programming if the door is open - or if the microwave thinks it is due to a bad door switch or door switch mount, etc.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 07, 2008 | Microwave Ovens
Microwave Ovens Logo
111 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
