Question about Avid Xpress Pro - (bundle) (05600360101) Video Capture
Unsupported pixel format problem in avid/editshare
An 'Unsupported pixel format' error is coming up in avid. We're using editshare over a number of computers. It's giving me the options to quarantine, ignore etc.
Any ideas?
Thanks
  • Anonymous May 11, 2010
    Are you using the same version of Avid on all the machines?
How to overcome error of unsupported resolution for any other video format in Samsung star II duos GT-C6712 & how to install other video software?
YOUR MOBILE DISPLAY RESOLUTION OR PIXEL IS 240X400 HERE IT THE SOFTWARE TO CONVERT VIDEO IN RIGHT FORMATION DOWNLOAD THIS SOFTWARE THE LINK IS http://www.megaupload.com/?d=9ZOPRGAQ 1] Install
[2] Use Serial provided to register
code: 308529876O7300I779741E74-C568-6382-E469
code: 555443568Q9676O21923B9D6-B5E1-647A-577C
code: 021685166O5807P60476AEC2-257D-BCFD-4644 THANKS
Jul 01, 2011 | Cell Phones
My Samsung GTS 5263 Does not support mp4 format(gives error unsupported resolution) but when i record video it stores in mp4 format and plays as well
The resolution is how many poxels are displayed on the screen at one time, there was too many pixels (the resolution was too high) on that video. You would have to download software to change the reolution. Here is a tutorial of how to do it using Format Factory
http://www.ehow.com/how_6816842_change-resolution-mp4-file.html
Pleas give me a muchly apprechiated rating
Thanks
Jun 08, 2011 | Samsung Star GT-S5233 Cell Phone
Unsupported format
I have the same problem. When I put in a dvd it tries to read it and then comes back unupported format. What does this mean and why won't it read the dvd?
May 05, 2010 | Bose 3 2 1 GSX System
Erro6: unsupported pixel shader version 2.0
Erro6: unsupported pixel shader version 2.0 resient evil 5 pc jogos
Sep 28, 2009 | Capcom Devil May Cry 4
Resident evil 5 benchmark unsupported pixel shader version 2.0
The game needs Pixel Shader 3 support, which is found on GeForce 6 series and up, and Radeon X1k series and up,
Sorry but a video card upgrade is a must to play this game.
If you're trying to run it on a laptop then you are probably out of luck as they're not upgradable.
Aug 09, 2009 | Capcom Devil May Cry 4
ERROR: Un supported pixel shader version detected, 2.0
You get this error because your graphic-card (architecture) is too old to run the game. To run the game you need a graphic-card which supports at least pixel shader 3.0, whil your card "only" has 2.1.
In case you're sure your card supports pixel shader 3.0, you'll need to update the graphic driver and/or DirectX (component of Windows) to the latest version(s) and try again.
If you're not sure wether your card support pixel shaders 3.0, you can post the brand, name and type of your graphic card here and I'll reply. When the card doesn't support 3.0, there is no other solution than simply buying a newer card (or don't play the game).
May 26, 2009 | Capcom Devil May Cry 4
Techincal solution
Do you mean .omf and .mxf? On mac the souce files are quicktime. Audio, generally works with .aff the best but can use .wav also. Though that message seems to suggest it is an audio card problem. I'd check if you can record in other sofware programmes and maybe if you have an on board sound card as well as an external one (if using PC) turn the on-board on off in MSDos as it could be conflicting.
Mar 31, 2009 | Avid Xpress DV 3.5 (0500-03677-01) for PC,...
HOW TO GET PIXEL SHADER3.0
Pixel Shader 3 is a hardware feature. You can only get Pixel Shader 3 by getting a new graphics card, as it cannot be 'installed' with software. Please don't use all caps, it doesn't make people want to help.
Feb 01, 2009 | Generic Memory nVIDIA FX5500 256MB 8x PCI...
Avid Xpress Pro - (bundle) (05600360101) Video Capture Logo
1,420 people viewed this question
Top Avid Televison & Video Experts
Marvin
Marvin
Are you an Avid Televison and Video Expert? Answer questions, earn points and help others
