Have HP printer 1125 - with bottom orange light blincking. I have changed the ink cartridges (refills) - and now it does only process blank pages. any help?
  • 100 Answers
U can change the ink cartridges and check it. If same problem continue in ur printer then u take from nearest service center.
Better to refill less than two time per cartridge.Everytime dont refill cartridges.Better to purchase new one and put it.
Thanks
Posted on Mar 07, 2008
  • Sachin Balgi
    Sachin Balgi Mar 07, 2008
    As per as my knowledge goes.U disconnect USB cable few min utes then reconnect.Take continue 2 to 3 sample printout and check it.
    Thanks
    President:
  • 1,944 Answers
Did you try disconnecting your printer for a few minutes and then reconnecting?
  • Damen Wong
    Damen Wong Mar 07, 2008
    This should reset the printer.
How do you get the ink to work? I put in new ink and when I am printing a page, the page is blank.
If the ink cartridges is a refll, generic (not HP), a lot of HP printers will only use HP ink cartridges that is new , no refill's...Sorry I had the same problem...
Sep 19, 2011 | HP Deskjet D1341 InkJet Printer
The color cartridges have all been replaced in the HP Officejet Pro K850 now all the pages are printing blank?
Try re-seating the ink cartridges and printing a test page. Those were new HP cartridges, right? Not some garbage from a ink cartridge refiller off ebay?
Mar 28, 2011 | HP Officejet Pro K850 InkJet Printer
My HP Photosmart printer was printing just fine until I had to change ink cartridges. Now it won't print anything, it just spits out a blank page.
Sometimes your printer print blanks pages, if your printer is out of ink. You can check the quantity of ink in the status of the printer. Sometimes, your printer displays messages if it is out of ink. So if you are facing such issues, you need to refill the ink in your printer. Communication problem with the printer and computer is also a reason for printing blank pages.
Jan 03, 2011 | Office Equipment & Supplies
I have a f4480 hp deskjet. How do you reset settings when you refill the ink (black) cartridge? Because even after injecting the ink, I still get the exclamation mark and orange light. And when even...
Some Hp printers, like Epson, require the cartridge to be reset. There is a chip on the cartridge that needs resetting.
This might work;
Place the HP 60 cartridge on a covered surface so that the metal contacts on the cartridge are facing you. Put tape over the top metal contact in the second column from the left-hand side, making sure the other contacts do not get covered. Put the HP 60 cartridge back into the HP printer. Print a test page when prompted. Take the cartridge out of the printer. Leave the tape on the contact that is already covered and also cover the top contact in the column at the far right, making sure no other contact gets covered in the process. Return the cartridge to the printer again. Print a test page. Remove the cartridge from the printer again, remove the tape from the metal contacts, and return the cartridge to the printer. Print the test page and the printer should read the cartridge as full.
Jun 18, 2017 | HP F4480 All-In-One Printer
Copier appears to be functioning well, but page comes out blank
You actually answered your own question, you said it started fading and came out with lines missing. Looks like and could possibly be that the ink cartridge you are using wasn't as full as you thought it was, and the computer really has no idea, it's just software and i do not recall seeing sensors on the inside of the ink tank to tell the computer how much ink is in the cartridge. Try refilling the ink again or maybe a better idea is to buy a new cartridge since over time the cartridges can get contaminants in them which will block the ink from the inside of the cartridge.
Hope this helps
May 31, 2010 | Canon PIXMA MX310 All-In-One Printer
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Will not print alignment page. all 3 light on front panel begin blinking
hi, there is the Solution
IF YOU WANT TO SKIP THE ALIGNMENT PAGE, Press and hold the Setup button, and then press OK . the printer not prind very very well, but the product works.There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
    THE COMPLETE ARTICLE IS HERE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=311255〈=en
Apr 07, 2010 | HP Officejet 5510 All-In-One Thermal...
Hi, I have an HP F4280 printer and the orange light of the color ink level is always lighting so i can't print anything (I am sure that my color cartridge is not already empty). What can I do? Oh yeah,...
There is only enough ink in the HP 60 cartridge to print approximately 200 pages. Also, the ink stored in the cartridge can dry quickly even it it's not used so you may be out of ink or the ink in the cartridge has dried up. Refill your cartridge with a kit or replace it with a new one. The ink level indicator is only an estimate any way. See pg 72 of the user manual which you can obtain here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jun 05, 2009 | HP DeskJet F4280 All In One Printer InkJet
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Won't print
Clean the ink cartridge maybe sticky on the ink outlet. sometimes refill ink don't work because that problem. some people soak the the cartridge in lukewarm water and clean it. other work and some other don't. so next time do not refill ink to way from this issue. thank you very much.
Jan 25, 2008 | HP DeskJet 722c InkJet Printer
Computers & Internet Logo
David Payne
David Payne
