Question about Oracle 10g Database Standard (ODBSEONUPP0)
Recovery of my files at usb
My usb be cant be detected....it will only blinks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
Did you try booting the PC with the USB device already attached? That will help the PC with realizing that indeed, there is osmething else there, and a driver needs installing. After that, all other things being equal, you should be able to plug 'n play the device after subsequent restarts.
Posted on Mar 10, 2008
Storejet 160gb
I have had just had this issue with one of my clients external drives. In most cases it will either be the outer shell/usb headers that are faulty or the hard disk itself is faulty.
The power light coming on, the drive spinning up, light blinking etc are good signs but by no means an indication the drive is in anyway working.
It is quite likely your drive has failed. To check this I would extract the drive from the external USB shell/caddie and connect the inner hard disk through other methods. For example another USB caddie. If you find the drives detects, installs and operates ok you can safely assume the previous shell/caddie was at fault. If you find the drive still does not work I would run a test with Seatools:
SeaTools Seagate
If the drive fails Seatools diagnostics or simply does not get detected by the system I would say the drive had failed and needs replacing.
You may want to recover your data if drive failure is the conclusion of testing, this free tool may be helpful to you in that case:
Recuva Undelete Unerase File and Disk Recovery Free Download
Alternatively data recovery specialists could be helpful to you, below is a link to a company I can recommend:
Fields Data Recovery
Mar 18, 2014 | Computers & Internet
My lg xd2 Coup mini 500gb is not working but the blue light is on but not blinking.What shoud I do?Do you have any software?I want to save all my files.Please help me.
If your 500GB drive is not detected by your computer at all you will need a pro data recovery service. If it is the case where it is detected then the first thing to do is determine the condition of the drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Sep 11, 2011 | LG XD2 500 GB USB 2.0 Portable External -...
Cant open the drive
Asoftech data recovery software is comprehensive recovery software for any Digital Media. It features an extremely easy interface and powerful functions that allows users to recover deleted and lost photos, music and video files from USB Drive, Pen Drive, memory cards, etc. The software works with Microsoft Windows 2000/XP/2003/Vista and Windows 7, and it's very easy to use.
http://www.asoftech.com/adr/
Aug 28, 2011 | Memorex Mega TravelDrive 4 GB USB Hard...
Cant be detected
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
Aug 19, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Usb cannot formatted
First of all, you'd better recover all your files on usb. You can download a data recovery program, recommended asoftech data recovery as it helped me before. You can read more info about data recovery from
After you get back all your files, you can try to format the usb. First check whether the usb is locked, and then you can try a low level format.
Apr 18, 2011 | Electronics - Others
MY USB FLASH DRIVE IS DETECTED BUT CANT BE SEEN ON MY COMPUTER? HOW WILL I FIX IT TO RECOVER MY FILES.. HELP ME PLS
(Windows 7) - Control Panel - ( make Large Icons) - Folder Options - View (check "Show hiden files,folders and drives"). Then go to C:\\ and look for "Ur-Smart Data" Folder (Delete it). (That's solution!) for more contact me : resul-rustemi@hotmail.com
Feb 16, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Cant Format pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 01, 2009 | Transcend (589307) Media
Transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
Jun 08, 2009 | Transcend (589307) Media
I cant detect my USB external HD for more than a minute.
There is probably a fault within the hard drive, the circuitry of the housing or perhaps the usb lead.
It would be as well to check the power supply first as some of them are less than reliable and are apt to provide too much voltage.
Jun 01, 2017 | Seagate 80GB USB 2.0 External Hard Drive...
Usb flash drive corrupted
try other usb port, or other computer, if still have problem, download a usb recovery software, one I used before is Asoftech Data Recovery, you can follow this guide for usb recovery
usb file recovery guide
Oct 18, 2008 | Electronics - Others
Oracle 10g Database Standard (ODBSEONUPP0) Logo
23 people viewed this question
Top Oracle Computers & Internet Experts
Bonded Repair
JonSnell Electronic
JonSnell Electronic
 steve
steve
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
