Question about Kenmore 16225 Grill
No blue flames
When turn on my grill, the flames is not blue like it use to be. It's a bright yellow flames and the no flames all around the burners. it's only flames on the back half of all three burners.
  • 833 Answers
Sounds like the burners have worn out. Replace them.
Posted on Mar 16, 2008
The flame coming out of my burners is yellow
Lack of air blocked burner needs cleaning blow out with air line or clean with wire brush .
May 08, 2012 | Tec Sterling II Grill
Left burner produces a normal blue flame, but the right burner produces a big yellow flame - how can I fix this?
Hi inomura...
Look at the left burner, pipe,air hole adjustment,etc because it is operating good.
You will see a difference to it compared to the on the right.
The right pipe, air hole, or the length the pipe that are iserted in the gas control valve is different from the left.
The yellow flame indicates that not enough air is getting to the flame getting to the right flame ignition point.
The left flame is nice and blue...normal, the right is yellow indicating that not enough air is getting to the flame ignition point...look to see if the air hole adjustment is different than the one on the left...there is something open more or less, improperly adjusted.
Once you have it adjusted properly the right flame will burn bright blue just as it does on the left.
Please take time to rate me
Sep 04, 2011 | Coleman Roadtrip Grill LXE 9949-750
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
On Barbeque side burner it burns with a high yellow flame getting
Try using compressed air to blow out the burner and make sure the gas is turned off when you do it.
Apr 20, 2010 | Grilling
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Bright yellow flame, can't adjust
Check your burner tubes for spider nests. Clean the burner assembly and check all the holes. Eric
Aug 08, 2009 | Holland Grill Legacy (NG)
Yellow flame on the rear of my burner
Yellow is a "reducing" flame meaning low oxygen, whereas blue is an oxidizing flame. There is not enough air mixing with the gas. Clean out the pipes and free the air intake holes on the first stage of the burner assembly.
Jun 02, 2009 | Char-Broil CharBroil Master Flame Gas...
Burner adjustment
HE PART YOU REFER TO IS THE BAFFLE, TURN IT UNTIL YOU GET A BLUE FLAME
Mar 08, 2008 | Kenmore 632 sq. in. 16324
Kenmore 16225 Grill Logo
495 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
