Question about 2wire 2700HG-B Router (2700HGB)
Setting up Static IP
Ever since our ISP send us this 2wire Modem with a Router built in we had nothing but problems with our PC
  • EAOxCrawl Mar 07, 2008
    Right now I need to figure out how to configure the new modem so I can play my online games on my PS3 with no interuptions or disconnects. My ISP has not ben any help in this department so I met up with a guy from here who had asked me to post my problems here.
Setting ports for echolink on2 wire 2701hg-b router 5198-5199
Posted on Mar 08, 2008
How to configure a router
  1. Login to the router page but typing http://192.168.2.1 on IE
  2. Check if you have a WAN IP or Internet IP
  3. If it is 0.0.0.0 then there is a problem
  4. If your internet provided is Cable you may have to do MAC clone
  5. If your internet provided is DSL you have to configure the router in PPPoE mode
  6. You will get WAN IP and will be able to go online
  7. Change the SSID which is nothing but the wireless network name
  8. Change the security to WPA or WPA2 and setup a security key
Aug 17, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
My old modem broke so a friend let me use hers but i can't get it to work properly
Please get in touch with your ISP. In case your ISP don't provide support for this particular router ask for the basic setting what u need to do in your router.
Ask for the default IP address so that you youself can do these setting.
Hope this will resolve your issue
Oct 15, 2009 | 2wire 2700HG-B Router (2700HGB)
ADSL ISP provides same address for IP and Gateway
Can you manually change the WAN IP on the router?  If so, give it an IP like 123.12.167.5 and set the gateway address to 123.12.167.1.  If it asks for a subnet mask, give it 255.255.255.0.
If she has a Linksys router, you may need to change the operating "MODE" on it.  A lot of Linksys routers have 2 modes of operation---Router mode and Gateway mode.  For her configuration, make sure the Linksys is in Gateway mode.  This will fix the NAT problem.
Cheers!
Mar 26, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Mar 19, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
D-link DI-604
I didn't quite understand what you meant but Ill explain some stuff you to that might help.
From what I understand you have a dial up router/modem, which is external (outside of your computer/seperate), and you hookup your phone line to it, which then connects into your DI-604 WAN port.
WAN Static IP settings are related to the settings given by the ISP that stay constant. There are 2 types of IP, static and dynamic. I think dial up is dynamic, since you have to connect/disconnect through the phone when you want to get on, this causes the ip to change at each reconnect, unless your ISP treats it differently.
I have no idea what you want to get out of the WAN static IP settings, but this should be handled by the dialup router/modem it self, and generally you dont have to manually enter the static ip, unless the ISP requires it, in that case you would enter this stuff there. The ISP Gateway Address refers to the ISP's router address/modem, I think, since I never heard the term before.
After "My problem:", I didn't understand your problem and can't give you further info until you clarify. Also if you internet is fully connected and working, and you still have problems then you could try resetting the router, by holding the reset button for 10 seconds. This will erase all settings. If that doesn't help try unplugging the router, then holding the reset button for 5-10 seconds, then plugging it in at the same time, then it should be fully reset, unless I forgot how it was supposed to be reset. ( I used to have the same router)
Feb 27, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
2wire 2700HGV cannot detect wireless Linksys IP camera WVC54GC
Purchase a different router and return the 2wire to the ISP explaining it is not compatible with your equipment at home. You may need to provide them with the new router's MAC address.
Nov 21, 2008 | 2wire 2700HG-B Router (2700HGB)
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
2wire not finding broadband connection
I have tried also in the past, to set up a connection with this make of router with an ISP other than the ISP that supplied it and i was not able to get it to connect as i think the firmware is set to only recognise certain ISP IP addresses or MAC settings.
Aug 10, 2007 | 2wire (1000-400108-001) Router
Cable modem connection
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router. Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes. Step 3 Power cycle the cable modem and router: Turn the cable modem off (first) Turn the router off Leave them off for 2 minutes** Turn the cable modem on (first) Wait until you get a solid cable light on the cable modem Turn the router on Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes. Step 4 Follow step 1 and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not have a public IP address under the WAN heading, click on DHCP Renew and then click Continue. It may take a few minutes to obtain an IP address. Static Cable Connection The instructions below are for users who were given a static IP address from their ISP (Cox Business, TDS DSL, PacBell Business, Interbaun, InReach, Inficad, FlashCom, DCAnet, and Cavalier). Step 1 Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Home tab and click the WAN button. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided. If you do not know your settings, you must contact your ISP. Step 3 Click on Apply and then click Continue to save the changes. Step 4 Click the Status tab and click the Device Info button. Your IP Address information will be displayed under the WAN heading.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
2wire 2700HG-B Router (2700HGB) Logo
196 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
