Question about Canon i860 InkJet Photo Printer
Big black cartridge not printing
we recently replaced the big cartridge (3eBK) and now it's not printing black!! We did the test and the cleaning stuff but no joy!! Help!!
  • lolita5050 Apr 08, 2008
    Same here - did you find out if you bought another black it worked? Hate to spend the money but will try it! Also when I run the tests it prints fine just not when I want it to print?
  • 88 Answers
Try replacing your printer ink cartridges with a new one.Chances are you have bought a defective cartridge. If that does not work, pls try to check the slot for your black ink for obstructions, then replace your black ink cartridge.
Posted on Apr 09, 2008
After replacing black ink cartridge, black ink will not print
check the cartridge contacts in the printer \
a lot of time they geet covered in ink this will not allow the cartridge to print properly and cause headaches
clean with a baby wipe or a paper towel with soap on it
dry thuoly with hair dryer and try again
Aug 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
3eBk will not print. Canon MP780
Replacing the printhead may work, but it could be a problem with the cleaning assembly. Take out the 3ebk and run a cleaning, if the ink goes away on the pad where the ink cart. goes, then clean assy. is OK, and you need a new printhead.
Jul 14, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Black ink 3eBk wont print
Ok what you need to do is make sure that the ink cartridge is properly inserted all the way. If it's not then you won't be able to print out black ink at all.
Jun 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon i860 printer is not printing from the 3eBK cartridge. I changed the cartridge and have deep cleaned the nozzles. any ideas
Are you using OEM cartridges or reloads? Sometimes the reloaded cartridges gum up the nozzles especially the black ink. If you have not tried an OEM black cartridge I woud try it.
Apr 28, 2009 | Canon Office Equipment & Supplies
IP5000 3ebk problems
I had a similar problem. Pages in blue, but nozzle check in black. Tried what you tried. Changed the ink ($). Still no change. Then tried the maintenance option to clean the bottom plate. And now it is working. Go figure.
Apr 08, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Canon Pixma MP780...the 3eBK cartridge won't print.
I cleaned my print heads 7 times before it all cleared up. Another possibility is there may have been a piece of clear paper or sticker or something on the replacement cartridge - take the cartridge next to it out and compare the two to make sure they look the same.
Dec 02, 2017 | Canon PIXMA MP780 All-In-One InkJet...
Canon ip4000r doesn't print 3ebk (black)
First of all... have you tampered with the printer's firmware? If not, it's unlikely it became corrupted. But if replacing the ink cartridges with fresh ones, and using a new print head did not fix your problem, you may be out of luck.
Is this a new problem, or has it always been like this?
Could it be that the print driver is always printing photo? In that case, it uses the narrow black ink cartridge instead of the fat 3eBK cart. You should print a nozzle check pattern and verify that you see the 3eBK cartridge pattern. If you do, the problem is likely SOFTWARE... your driver settings, not the printer itself.
I hope this helps.
Dec 24, 2008 | Canon PIXMA iP4000R InkJet Printer
PIXMA MP780 printing trouble
If you haven't done so, I would try another new cartridge. It is entirely possible (and occurs frequently) that you got a bad cartridge. Assuming you removed the tape from the cartridge before putting it in, this is generally indicative of either a bad cartridge, bad print head, or that heads or ink tanks may need cleaning.
The Canon support page for this printer is at:
However, as Canon pages come up as generic pages (without the text I input for you), you will have to type in "missing black ink" (without quotes), to see the material they have posted in this regard. You will find instructions there in regard to how to clean the print heads, etc., if that is necessary. However, I would definitely try another cartridge first, especially if you haven't had that much use on the printer, such that you think these other measures may be necessary.
Please post back if you need further help, otherwise thanks for rating FixYa!
May 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Jul 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon i860 InkJet Photo Printer Logo
120 people viewed this question
old marine
old marine
