Question about Zanussi FS1255S Front Load Washer
HOW CAN I FIX BOSCH WFF 1401. NO POWER OR NOISE
I have checked the fuse but power is getting through. what else could it be.
please advise. THANK YOU.
  • 59 Answers
Funny enough check the fuse again you could have installed a duff
make sure it's 13amp or on the fuse it will say 13A
DO that untill lights come on on the front or something.
Or if it comes to the worse and its under 8yrs old get it covered by domestic & genreal
Domestic & General is the UK's leading specialist provider of extended warranty cover for electrical domestic appliances and also provides repair protection for central heating systems
of cause don't be stupid and tell them that its broken at the time of taking out the cover, lol
get it covered leave it a week or so then report it to them as faulty
This is not an advertisement for them - and i don't make anything out of you using the link above it is NOT a affiliate link
go 4 it
Posted on Mar 07, 2008
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
How to replace timer bosch wff 1401
Is there a code that pops up on your panel and if so what is the code?
More than likely it's in your panel but, it should pop a code.
Aug 27, 2014 | Bosch Washing Machines
Heating problem
put new heater in then
Nov 27, 2011 | Bosch Washing Machines
I have a bosch clasixx 1400 washing machine and it is not spinning but is going through all the programmes and i have also changeed the carbon brushers, what is wrong?
Make sure the filter is clean, this is located at the bottom front right of washer, unscrew anti-clockwise to remove and clean.
Mar 09, 2010 | Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Instructions on how to use bosch wff 2001 washing machine
hi if you look on the main bosch web site you can find a list of manuels for bosch washing macine witch are free to down load in pdf format hope this helps tim automan.
May 23, 2009 | Bosch Washing Machines
Bosch washing machine
With no clothes in the washer start a program. The washe level is below the door glass. the rinse level comes up 3 cm on the glass. The washer is designed to be water efficent. If you are not getting water this high, look at the pressure switch hose, maybe it is restricted and causing the pressure to be held in the washer.
Jan 19, 2008 | Washing Machines
Washing machine - Bosch WFF 1401 - spinning problem
Bosch WFF 1401 This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2007 | Washing Machines
Zanussi FS1255S Front Load Washer Logo
259 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
