Question about Zanussi ZWF1430W Front Load Washer
Machine won't wash with clothes in it
Washes fine when it's empty, machine is only a year old!
Sounds like the drive belt needs adjusting
Posted on Mar 07, 2008
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
WF250 washing machine. Drum smells and clothes smell a bit too. have tried boil wash but no improvement. Washing machine is 6 years old and has no other faults. Can you help?
Due to mainly running low temp washes and bacteria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe) many machines will begin to smell, generally the smell is described as a damp flannel!. This can be transferred to the wash load if like myself you tend to put a load on before going to work and then removing when you get home. (The washing is clean but smells disgusting!!!)
Run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) If you buy stores own as it is cheaper than miltons. The first time you need to do this, run the cycle twice to be sure it was cleared out.
My machine is six years old and the first smelly signs were when it was about a year old, I do mainly 30 and 40 degree washes with and occasional 60.
I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months.
Hope this helps. Roni.
(ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Sep 11, 2011 | Hotpoint Aquarius WF000 Front Load Washer
It wont empty out completely clothes are still. The drum itself is very loose not sure if it suppose to be that way. It does not spin very fast . does this particular model have a belt that needs to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Washing Machines
Washing comes out with marks
Yank that dispenser off the top of the agitator and wash some clothes without it.
Apr 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
Jan 06, 2010 | Zanussi Washing Machines
Leaking maytag
it could be the pump but there is a seal in the tube where the transmissin goes through the tub that seal has a common problem of leaking but if it 10 years old i would replace the machine
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Will not agitate to wash clothes but will spin fine
call a repair man. you cant fix this yourself
Apr 26, 2009 | Washing Machines
Zanussi ZWF1430W Front Load Washer Logo
24 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
