Question about Cuisinart Thermal DGB-600 Grinder
Leaking coffee pot
My coffee pot of 2 yrs just started leaking??? Any suggestions?
  • 3 more comments
  • Anonymous Mar 08, 2008
    My cuisinart leaks from the bottom - any solutions?
  • antman717 Jun 22, 2008
    There is a puddle of water under the unit before brewing begins. +/- 1 year old coffee maker. Any suggestions?
  • rmcantore Dec 01, 2008
    Did you find out anything because I have the same problem. I fill it to make coffee and it leaks out the bottom of the pot.
  • montreal1235 Jan 10, 2009
    I also have the same problem Leaks from the bottom of the unit Has anyone gone back to the manufacter with this problem with any results
  • resteves May 14, 2009
    Everytime I'm making coffee when I come back for my cup of coffee the coffee maker is leaking from bottom
  • 7 Answers
Same problem - obviously this problem needs a rocket scientist to attend.
Posted on Dec 22, 2009
  • 5 Answers
Sometimes if the unti is very full with water, even @ the 7 cup level, when i push the unti backwards into it's space water can easily splash out the back of the unit makin me think it has a leak. Make sure this is not the case, Good luck, Steve
Posted on Aug 02, 2009
Mine did that too... Only suggestion is to place a towel on the counter...
Posted on Mar 23, 2009
DCC-1200 leaks coffee onto carafe and warmer plate
My coffee pot was leaking over the carafe and onto the warmer. I found that this issue was caused by the carafe lid. The lid was not allowing coffee to flow into the pot fast enough. I removed the inner mechanism from the carafe lid (it pops off really easily) and just sit the lid on top of the pot while brewing, and no more leaks! After brewing, I put the mechanism back onto the lid and twist lid onto the pot.
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
My cuisinart brew central, 8 yrs old and still going strong - until now, just turns off after brewing 1/2 pot of coffee. I can turn it back on easily by hitting the toggle swithch. Just started to do...
Hi, Eight years is unreal. I was going to suggest that the boiler elelment i s starting to fail, but i think it could be a thermal cut out which is positioned on the boiler. Thermal cutouts are connected to the main toggel switch. The thermal cutout turns of the power when activated. You can check it wity a meter (approx 12kOmhs). Id replace the thermal cut out anyway. They do ware out.
Sep 26, 2011 | Cuisinart DCC-1200 Coffee Maker
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
My daughter made a 1/2 pot of coffee in our Bunn. Now evcry time we make coffee water is all around the base. We poured all the water out and started over and it still leaks. Help?
sound like a gasket is bad. really nothing to do with brewing a half a pot. theirs not much can be done but replace the brewer. are you covered by warranty??
Jul 05, 2009 | Bunn NHB Coffee Maker
Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
Jan 11, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn Coffee machine only makes 1/2 pot
What's happening is that it isn't leaking, it's boiling over. You need to turn down the thermostat under the top lid. Also, before you brew coffee, add water to the tank and let it pour into an empty pot. Once it stops brewing, let it heat up for a few minutes then make your pot of coffee.
Jan 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Kenmore Microwave / coffee maker leak
I have a Kenmore Microwave with built int coffee maker (Model 721.63999303). The coffee maker works, but the microwave doe not. Can the microwave be fixed ?
Apr 12, 2008 | Kenmore 63993 Microwave Oven
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Nov 30, 2007 | Cuisinart Coffeemakers
Cuisinart Thermal DGB-600 Grinder Logo
379 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
