Question about Hannspree HW191D LCD Monitor
No sounds from monitor at all
Went through all the usual routes.
Volume control, new driver, uninstal/install nothing works.
So anyone any ideas?
Cheers
  • 2 more comments
  • hamish260 Apr 28, 2008
    Another programme, changed all the sound settings when it was deleted from the PC.
    Thanx for the help.
  • Anonymous Jun 24, 2008
    no one
  • noniemyers Jul 21, 2008
    I have no sound on my monitor. Have trird ever thing. Had HP help try. Should I retrun all and start over.
  • lush_us_lucy Jul 24, 2008
    hanns.g hc174d no sound coming through speaks of the monitor does anybody download disk info for this monitor please x
I have the same problem can someone help please
Posted on Oct 05, 2008
    Scholar:
  • 101 Answers
Is the sound cable connected from the pc to the monitor. Sounds obvious but often overlooked.
Posted on Mar 07, 2008
I have the same exact problem.
Posted on Apr 27, 2008
Windows 8 headphones not working
If the speakers are working, the drivers are installed. Check the configuration in the sound control panel for a muted volume control.
Dec 26, 2013 | Computers & Internet
At first Ithought it was my monitor, so I went and bought a new monitor. Hooked up the new monitor and monitor is still blank. It turns on Windows XP and then a little box comes up "sleep mode"...
Have your tried booting into "Safe Mode" ? minimal video drivers are used, allowing you to go in to
  • Control Panel
  • System
  • Hardware
  • Device Manager
  • Display Adapter , Uninstall your old driver
  • Reboot , this allows yours system to clear the registry
  • Re-install video drivers for new card
Feb 24, 2011 | Computers & Internet
Hi , I own a viewsonic LCD monitor model va1912w. My system has Windows XP. There is no sound from the monitor even after connecting the sound cable from CPU to monitor's audio jack. I have already...
http://www.viewsonic.com/support/downloads/drivers/?prod_name=1912
Try the above link for Vista or XP drivers which may be used with Windows 7 in some cases.
The va1912wb came up when I searched under 1912.
This driver is available directly from the viewsonic.com site.
Uninstall the other driver if possible.
Aug 08, 2010 | ViewSonic VA1912w 19" LCD Monitor
May volume keys on my keyboard are not responding. My speaker/headset volume is inaudible. whenever I press the volume keys on my keyboard, nothing happens. the same as when i click the volume symbol on...
They are actually two separate issues:
I will assume that you have funtioning speakers or headset.
1) first fix your main audio problem by re-installing your sound card driver that would normally come with your PC/Laptop or (external) Sound Card. This should fix the issue with your software volume control
2) second fix your Keyboard volume control: if after fixing your audio system driver previously, this is still not working, then you will need to re-install your Keyboard 'soft' key driver that control the extended function of your specific keyboard: the driver may also be included as part of your PCLaptop but may also have come with a 'third party' non-orininal keyboard.
Hope it helps & good luck!
Dec 25, 2009 | Computers & Internet
Screen is blank, computer makes all proper sounds as if booted correctly. the volume up and volume down LED's flash, also, the number lock light stays on. dell studio 1536
Sounds like your screen went out. Try hooking a monitor into the blue port on the back of the laptop. If the screen shows up, the LCD probably either came disconnected inside or the inverter went out. This is a simple fix for a qualified professional. If not, press fn and F11 (the f key with a picture of a box with an arrow in it). If the screen still doesn't come on, it's most likely the video card or motherboard, which usually is more expensive than the computer to get fixed.
Nov 18, 2009 | Computers & Internet
No sound on monitor
I will assume you have checked the cables etc to make sure they are not bad in any way and skip to the more usual problems
Make sure they are powered up and the volume is about half way if they have a separate volume control. (not all flat monitor do)
First check that they were not MUTED by accident. A red line through the speaker icon would indicate this and you would just need to untick the MUTE box.
If its not as simple as that then carry om below.
OK now you need to call up ether the sound card application or preferably the windows volume control from the bottom tool bar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else)
Now close the slider box.
Put a normal music CD in your CD/DVD player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
If all went well you are running but if not you know just may want to check the hardware properties and should there be an exclamation mark against any of the sound hardware you know where the problem is.
This can in most cases be fixed with an updated driver for your sound card.
Sep 03, 2009 | FujiPlus FP-7688B 17" LCD Monitor
No sound dell Inspiron 8200
If your touch pad doesn't work too, there is a connector under the keyboard that affects both the sound and touch pad. It may have come disconnected.
Jul 20, 2009 | Dell Inspiron 8200 Notebook
No sound
TRY INSTALLING AN AC'97CODEC DRIVER FROM REALTEK.RICHARDM69
Dec 15, 2008 | Gateway 4540GZ Notebook
Sound
YOU MAY NEED TO DOWNLOAD A NEW AUDIO DRIVER OR INSTALL A SOUND CARD IN YOUR SYSTEM.
FIRST go in control panel select sounds and audio devices OPTION and click on adjust volume look to see if your volume is up and make sure the mute option isnt on if this doesnt work proceed to find audio driver via the internet.
Jan 16, 2008 | Princeton Digital VL17151 17" Flat Panel...
Hannspree HW191D LCD Monitor Logo
274 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
