Question about HP Pavilion Notebook
No display-- i would start my hp dv2 and only the blue led is on but there is no display whatsoever in the monitor/screen
  • emaffet Mar 10, 2008
    hp dv2000 the model of my laptop..all i can see when i start it up are the blue led and some beeps-- can anyone give a solution??that would be of great help..thanks--
  • Sunny30 Jul 09, 2008
    I start my HP Pavilion laptop and i get the blue lights on my keyboard but nothing comes up on the monitor, what do you suggest? Help Please am pretty good with instructions!!! Thanks in advance!!
Your computer has memory problems. 1st check video. If video is working, you'll see an error message. If not, you have a parity error in your memory. Check your memory. Reseat them and try rebooting your computer. If this doesn't do it, the memory chips maybe bad. First banks are the memory banks in w/c your cpu finds its 1st 64k of base memory. You'll need to consult your manual to see w/c bank is 1st.. If all of your memory tests good, you probably end up buying new motherboard.
One long beep and two short beeps indicates that the GPU chip is not working.
I have found that the GPU gum between the GPU and the heatsink is meant to fill about a 2mm gap, but the gum dries out and cracks. When this happens the chip overheats, and the BGA pins on the gpu loose there connection. If you leave the power on after the beeping and block the vents a bit, the GPU/CPU heat sink warms up enough to expand the solder on the BGA pins and make a connection and the laptop will run. But eventually the solder will fully fracture, and a ball may come off and then you are totally stuffed.
Fixing the heat sink does not fix the problem - its the cause of the problem though, so if you do get yours fixed, I would recommend opening it, scrapping off the blue gum, and inserting a 2mm peice of copper plate on-top of the GPU and using siler thermal paste to connect the GPU to the copper plate and then again on the other side to connect to the heatsink. But this won’t fix it if its already dead. (I tried it and I get the same long beep, two short beep).
To fix the problem you have to re-flow the solder on the BGA. This should be done as a last resort (after your laptop doesnt turn on any more even when you heat it up). You have to strip down laptop to the motherboard. Bake the motherboard in a fan forced over at 80 degrees celcius for at least 24 hours (to get rid of any moisture that might be in the chip or solder). Immediatly after you take it out of the over, you need a hot air gun capable of reaching about 300 degrees. Heat the entire GPU chip and its board (don’t worry - all components can take 300 degress celcius for solder-reflow and did when the board was made). Keep bumping the GPU chip very slightly with a small screw driver, it will eventually become loose. Don’t lift it up however. Just keep the heat on for a few seconds to let the solder reflow and make a connection with the balls underneath.
After that let it cool down and plug everything back in and it *Might* work. If not can you heat it up and try again.
HP should never have used a BGA chip for the GPU. Its rediculous considering how hot the chip gets. I think nvidia are partially at fault as well - the 7200 uses to much power to be a bga chip.
Posted on Jan 20, 2009
  • 75 Answers
Hp dv2 this a monitor?
Posted on Mar 07, 2008
Hp pavillion dv2 1005ee notebook PC goes black screen whenever i started it. What should i do? Also its keys not working while this problem.
h
to test if it is the lcd screen tis faulty or the inverter
plug in another monitor to the external monitor plug
when you turn on the laptop if the 2nd monitor displays the desktop your lcd needs to be replaced
if its also black your inverter needs to be repalced
aries
Oct 19, 2013 | Computers & Internet
Vertical black bars screen
Try connecting an external monitor to the 15 VGA (video) plug on the laptop and see if it displays properly on the monitor. You may have to direct the video from the laptop to the monitor by holding down the blue <FN> (key next to the space bar) and then press down the <F8> key.
If the display on the external monitor is correct, then you either have a problem with the laptop's LED display screen or cable that connects the LED to system board. Here is a link for the service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-9300_service%20manual_en-us.pdf
Feb 16, 2013 | Dell Inspiron 9100 Notebook
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
HP vs17 (PK657AA) problem: the image is displayed for 3 seconds
first try entering VGA mode in the startup menu. u can get the startup menu by pressing the F8 key immediately after the POST screen. if the screen stabilizes try changing the resolution to 1024 by 768 which should work in normal mode. if that doesnt work then the monitors internal bulbs may be burnt. an electrician may fix this problem for you.
Nov 18, 2011 | HP Vs17 17" LCD Flat Panel Monitor
I have prolem in samsung LED that no display shown when i turn on....can you please advice. thanks....Peter
send me detail on jogindersingh47@yahoo.com 1) if yours LED power on and display of window not giving then problem from cpu. a. first replace yours RAM and check display. b. then display cable and check display. c. Install new Display card and check display, if not giving display it means motherboard have a problem 2) LED not giving power on then problem from monitor a. replace monitor power cable and check display b. monitor logic card have aproblem
Mar 16, 2011 | MPC Computers AOC 7F 17" CRT Monitor
I try to open hp dv2-1030us screen but couldnt
http://h10032.www1.hp.com/ctg/Manual/c01682742.pdf
Click the above link
this is the service and maintenance manual specific to your model. It should provide you with enough information to complete the job if you end up needing some help, drop me a line. good luck!!
Apr 04, 2010 | HP Pavilion dv2-1030us Notebook
Hp w2007 monitor: Powers on but screen is white - no display at all (no error msg..., just a bright white screen). Blue 'power led' is on. No difference when connected to pc or no connection. Flickers at...
This is an internal problem with the LCD monitor. It is defective and should be returned to the store your purchased it from for a new one. That is the only thing I can really think of if it is not reading properly with a seperate graphics card. It is an internal issue and needs to be repaired.
Oct 03, 2009 | HP W2007 LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
HP Pavilion Notebook Logo
203 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
