Question about HP DeskJet 930c InkJet Printer
Need help urgently
Both the power and the resume lights are flashing, when I press the resume button the cradle is not moving
  • davel3333 Dec 15, 2008
    on power up, goes through it's initialising sequence then all three lights flash on and off very quickly. The print carts do not move, even when you lift the lid. At the same time my pc is asking for driver for a HP 970ce
Tried this but did not work at first, so tried it again but left printer unpowered for one hour. Tried it again and works ok now. It did ask for driver software for a 970 again but ignored it and all is well again!
Posted on Dec 15, 2008
    Scholar:
  • 74 Answers
Try unplugging the printer from the computer, then turn off the printer with the Power button, next unplug the power cord from the printer for 5 minutes or longer, now plug the power cable back in and turn on printer without connecting to the computer. If the lights have stopped flashing, reconnect to the computer (if using USB) or power off first if using a parallel cable.
Add comment if still having trouble. Hope this helps.
Posted on Oct 18, 2008
Waiste tank full and not printing need reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
i hope this helpful
thank you for using fixya
Mar 09, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
Orange light flickers 6 times green light the 7th
Hello there you can try this may work
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. Service/factory test printout, including ink sensor check
2. EEPROM info printout
3. EEPROM initialization
4. Clear the waste-ink counter
5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
Canon S9000
Turn off printer
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 11, 2010 | Canon S520 InkJet Photo Printer
12 flashing yellow lights
1. Turn off printer
Oct 20, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
8. Your printer should respond as normal..
Jun 02, 2009 | Canon PIXMA iP2000 InkJet Printer
Pixma ip 3000 power on all the time no functions. cannon
1. Turn off printer
Nov 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Flashing lights
1. Turn off printer
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
My Heward Packard desktop 932C will not connect to my Dell laptop
what kind of connectivity you are trying to connect, most connectors comes as a USB cables, this comes as a easy connector that should be no problem at all, pls follow this info...
This document describes the hardware setup for a new printer. Unpack the printer
  2. Turn the knob on the rear access door of the printer counter-clockwise.
  4. Push the module back into the printer until it snaps firmly into place. (Do not press the buttons on the ends of the module while replacing it.) c00107976.gif
Insert paper
  1. Slide the paper adjuster out as far as it will go.
  2. Flip up the OUT tray so that you can see the IN tray more easily. c00107977.gif
  3. Place up to 100 sheets of printer paper face down in the IN tray.
  4. Slide the paper adjusters to fit snugly against the edges of the paper.
Turn on the power
  1. Locate the power module for the printer.
  2. Insert the rectangular end of the power supply cord into the power outlet on the back of the printer.
  3. Insert the two-prong end of the cord into an electrical outlet. c00107979.gif
Insert cartridges
  1. Open the top cover of the printer. When you open the cover of the printer, the RESUME button will flash until you close the cover. The printer part that will hold the cartridges (called the cartridge cradle) moves to the center of the printer.
  2. Remove the ink cartridges from the box.
  3. Remove the tape from the cartridges. c00107981.gif CAUTION: Do not touch the copper contacts (on the back of the cartridges) or the ink nozzles (on the bottom of the cartridges).
  4. Lift the cradle latches inside the printer.
  5. Hold the black ink cartridge vertical, with the copper electrical contacts toward the rear of the printer.
  6. Push the black ink cartridge firmly down into the cradle on the right. c00107982.gif
  7. Hold the color ink cartridge vertical, with the copper electrical contacts toward the rear of the printer.
  8. Push the color ink cartridge firmly down into the cradle on the left.
  9. Close both latches. When you push down the latches, you will hear a click and feel resistance.
  10. Close the lid of the printer. You will hear the sound of the cartridge cradles as they move to the right side of the printer.
Attach the printer Attach the printer to the computer with a parallel cable or a USB cable. Print a test page Turn the printer on and press the RESUME button to print a test page.
  1. If the RESUME light continues to flash, press it again.
  2. If the printer cable is firmly attached to the printer, then check to be sure that the printer cartridges are seated securely in their cradles.
  3. If the printer cartridges are seated firmly in their cradles, then check for any tape or packing material that you may have left inside the printer or on the cartridges.
  4. If you press the RESUME button for too long, you may print several test pages unnecessarily.
check it out.... goodluck
Jul 27, 2008 | Office Equipment & Supplies
Power & Yellow Resume Button flashing constantly & will not print
Ok please try
1. Turn off printer
Jun 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Cannon BJC 80
5 times try this:
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
3 times, probably something wrong with the cartridge.
Nov 21, 2007 | Canon BJC 80 InkJet Printer
HP DeskJet 930c InkJet Printer Logo
169 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
