Question about Compaq Presario 5000 PC Desktop
Blinking red light
I have a packardbell pc. my computer infected so i formated and installed every thing back, the pc was working fine. i decided to clean inside the cpu with canned air. i did that and put every thing back together no the pc doesnt start only the statue light that shows wether the pc is on or not blinking.
i wonder if u could help me plz.
i personly think the processor is dead.
thanks
    Sergeant:
  • 406 Answers
If you are not getting any beeps etc . Please note that you have fixed every thing in proper way.
Kindly be suggested that you do not do the repair at this time if you do not know all the connections. If you do not know take the assistance from your friend or a technician.
If you know Fix all the heat sink of CPU and cpu proper ly,
see that ram and VGA card and other card s are in a proper position.
Best Regards
Rafique
Posted on Mar 07, 2008
Dram Led on my motherboard blinks red twice
Don't panic. take a good light above your computer and start checking if every card and every connector is still correct inserted. Feel if nothing is lose. Even cards you did fasten with a screw, remove the screw and look and feel if the card was inserted correct. Everything you inserted in the motherboard should be checked. It could be a card you did not put in correct at the first time, but still made contact and only got lose because of some tension to shock.
Jul 03, 2014 | ASUS - MOTHERBOARDS Asus M5a97 R2.0...
No internet connection in my Laptop after installing Windows-XP Professional
http://www.packardbell.co.uk/pb/en/GB/content/download
Go to this link and enter your SNID, should be on the bottom. Select Windows XP and download the lan and wlan drivers. Of course you will have to do this on a computer that connects to the internet. Copy the drivers to a usb drive and install on the laptop.
Dec 15, 2012 | Computers & Internet
I received a corrupt file message and for some reason i decided to restart my pc. the green power light comes on as well as the red light which blinks. after a few seconds the red light stops and the...
The red light is the indicator for the HDD activity , since it stop it's clear that the corrupted files were essential ones, that should have been loaded during the Windows boot process.
Your only thing left to do is to reinstall. If you're lucky you can get away with a Repair install, try it first.
Jun 22, 2010 | Computers & Internet
My Dell Inspiron 10v is barely running: won't go past the Welcome screen without booting it from disk, open a program and it runs very slowly and becomes unresponsive, diagnostics came out fine, all...
I guess your OS infected via virus and that create some diffculty to run OS system. batter your run antivirus 1st . After finish then restart the system . if the same then you need to format OS and reinstal it ok.
Jan 29, 2010 | Dell Inspiron Mini 10v Netbook Computer
System hangs
i thing your laptop is problem with virus related fist you are parchesh bootabal antivirus cd and boot form cd and remove the virus and after your laptop is working fine .....ok
May 01, 2009 | Computers & Internet
Disk 1 unallocated
Try installing another OS on the same PC with a bootableOS. If you succeed then try to clean all viruses by an authentic/genuine Anti-virus. After that you should have access to your files for backup and then go for a clean install..........sodeep
Apr 28, 2009 | Computers & Internet
Virus free pendrive
goto my computer, right click on drive, choose format, do this on a non-infected pc
Apr 11, 2009 | Computers & Internet
No sound after installing windows xp
The drivers for your computer can be found here: http://support.packardbell.com/uk/item/?pn=P481000502&g=2000
Scroll down to Audio, and download the Via audio driver and then it. It should install all necessary files to communicate with your soundcard.
Mar 22, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Blinking red lights on startup
4x red blinking light on this system means it's "CPU thermal shutdown" this is done when the cpu fan fails to cool the cpu and the computer shuts itself down to keep you from burning up the system.
This could be caused by dirt, hair, dust in the cpu fan or heatsinc or because the fan has failed.
you can blow some canned (dry) air through the fan and heatsinc undernieth it and try to clean it. most likely you will have to take it off to clean it thoroughly or replace the fan. It is about a 15-20 dollar fan and your local computer shot or neighborhood computer guru can replace it in 10 minutes, so dont let then keep your computer longer than a day.
If your computer savy, remove the case, inspect the fan while the computers ON to see if it sounds weird or is not coming on at all. it has usually two retaing clicps the can be difficult to remove with the power supply in the way. so be ready with a philips head screwdriver and a notebook to write down anything you dont want to forget to put back. If you decide to tackle it, post again here after you check the above mentioned things and ill get you a detailed breakdown of how to do it. It real is not too hard.
Regards..
Oct 29, 2008 | HP xw8200 PC Desktop
My computer is badly infected with unnecessary popups and it says it is badly infected. Please help
hi
try quickheal , avast, symantec with update definition oner bye one clear malware , virus and other melicious thing in safe mode.
othjer wise delete partition and format install new os.
Mar 23, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
