Hi now im having Intel P4 2.4 ghz processor with 512 mb ram
mother board is intel 845. but still the mother board having some problem so i decided to buy new board which one suitable for my processor and ram.
kindly advice me
karthik. V
[email protected]
Well that can depend on a number of factors like how much you are willing to pay.
Logon to newegg.com or zipzoomfly.com and search through their motherboards for ones that match your processor. pick one that has the features you want. Im partial to Asus boards so id find one of those that would match that processor. They list which processors will work with them so it really is pretty easy. zipzoom is my personal fav.
You shouldn't have any trouble. Minimum System Requirements for Fifa 09. CPU with 2.4 GHz (single-core) 512 Megabytes of RAM (1 GB required for Windows Vista?) DirectX? 9.0c Compatible 3D accelerated 128 MB video card or equivalent (must support Shader Model 2.0 or above) DirectX? 9.0c Compatible Sound Card 512Kbps or greater broadband connection for online gameplay MS compatible mouse Keyboard
today also some models of 845 chipset motherboards available in the market.Try to get the mother board cd of latest 845 chip set.
else you better go to xp
I have installed RAM of 256MB each (2slots total 512MB ) and system BOOTS UP, but it keeps restarted on every 5 minutes.
Please advice
It is 845 GLLY Original and 1.7ghz.
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS.... (This solution works for any Intel Motherboard)
No need to donwload or install any drivers. Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key and Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher" 2. Leave "Primary Video Adapter" as "Integrated" 3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button" 2. Right click on "Computer" 3. Select "Properties" option from the context menu. 4. Scroll down and find "Disply Settings" option and click it. 5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
try update the system bios because there were motherboards that had compatibility problems, this board is not a new one so it should work with your processor
