Question about Konica Minolta bizhub 250 All-In-One Laser Printer
MINOLTA CF3102 PRINTER
Powered, displayed a message, malfunction detected with C-0098
This code is related to fusing pressure, which could mean fusing unit malfunction.
Put paper clip through a hole under LED cleaning pads inside the front door to reset.
Caution!!! Not recommend for the end user to reset fusing related codes since it could result in a fire.
Posted on Mar 09, 2008
Minolta CF3102 questions
After resolve the problems,or change the supply to refer the message ,the tehn rep message displayed automattically.
Aug 02, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Not making copying and show error code no c-0098
Try reset the error code.
Turn OFF the copier,press and keep pressed the Utility key turn ON the copier wait to display appaire the Trouble reset message.Release the Utility key,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Mar 26, 2013 | Minolta C350 Printer
Hi there!!! My printer displays error message: malfunction detected call representative - c3751. Kind regards
hi this is a high temp code, you need to replace the fixing unit then get a service tech to reset the machine
si
Jun 05, 2009 | Konica Minolta bizhub C250 All-In-One...
Copier proplem
1. Reset the malfunction (i.e., turn OFF and ON the Power Switch).
or 2. If the same malfunction is still detected, check the EDH harness and, if it is okay,
change PWB-IB.
Feb 01, 2009 | Minolta DiALTA Di520 Laser Printer
Model cf3102 display misfeed detected
We get a miss feed on our when we load too much paper. Try loading a little less. To undo a miss feed from overloading it you have to open and close all the drawers and eventually it will go away.
Jan 29, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta dialta di250
The C0048 error code not exist.Malfunction resetting procedure:
Turn OFF,then ON the power switch or open and close the side cover for all malfunctions except C05XX codes.
Use Trouble reset of the Initial screen to reset all malfunctions.
To right side the touch panel(screen display)near display contrast button exist a little hole (reset switch).Insert a hairpin to touch the switch.
Enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screen being displayed.Touch TROUBLE RESET,and EXIT to go back to the basic screen.
May 07, 2008 | Minolta DiALTA Di520 Laser Printer
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
270 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
