Copier reset procedure.
Good morning.
Working on a Savin copier model 9220.
Fuser error code e 541
Need to reset error code.
Changed and verified fuser parts are in good shape.
Thank you
Franklin
    Scholar:
  • 45 Answers
Hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Posted on Mar 08, 2008
I have a Savin 8035e. I had an error code SC542 and reset the copier as suggested. Worked great. Problem now - How do I fix alignment?
That error code is a dirty fuser thermistor. Clean it and go into service mode then turn off main power switch. That is all that is required. What is out of alignment?
Oct 10, 2014 | Savin Office Equipment & Supplies
Error code E541
Ricoh Copier Error Code SC 541 is Fusing thermistor open problem
1. This is Open Thermistor problem
2. Thermistor connector is bad.
3. Thermistor is broken, or out of place
4. Fusing temperature -15% less than the regular input voltage
Might be a one time failure you can reset. Access service mode and reset the code then power copier off & on again. If problem goes away your good. If not.....time to replace the fuser.
Jul 27, 2012 | Ricoh Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
I have a service code CS541 for a Savin 2522 - I need to repair it
Ricoh copier service code SC541 refers to the fuser assembly having a problem.
Sometimes they code can be temporarily reset, however, it will eventually come back
and not go away!
While the printer is on do the following:
  1. Hold down both of the arrow keys for 10 seconds
  2. Press ENTER
  3. Select Option 2 for Engine
  4. Choose 7 Data Log
  5. scroll down to 7807 and execute it. click OK
  6. press the escape button until you get to the engine option
  7. then select option 3 to end
  8. restart the printer by pressing the power button.
If the above does not work, repeat the procedure but instead of 7807 look for SC calling, something like that, and reset the whole thing.
The reality is that the problem is fixable though, and do not need to purchase a new fuser, after clearing the code, the printer should work fine again
Jan 31, 2011 | Savin 2545DP Black and White Copier
Err c 0500
This error code is a fuser problem and maybe in my experience a morning problem.
Try to clear the error the error with this procedure:
Hold down utility counter for 3 seconds and in the screen will appear a trouble reset, then touch it and turn off and on the main, it will clear the error code.
If it does not see if you have fuser problems with the termisotrs and also check the power.
Jul 21, 2010 | Konica Minolta Bizhub 222 Black and White...
I have a Savin 9113Z copier that is giving me a error code of 54. Any advice
Hello sir; You do need to reset this error code, procedure as follow;
press 71,hold down "clear/stop"key, until you see the "." in the upper left cornor of the display, then release, after that you press "clear/stop" key again then press lighter key, the 5 will now flash on the display, now enter 97 press start, turn machine off and back on , machine should be running.
Jan 04, 2010 | Savin Office Equipment & Supplies
Functional error SC542
This is a fuser temperature heating error.
the fuser has not heated up within 5 minutes after switching the copier on.
Most likely cause:
Heater lamp blown
Thermal fuse blown
Faulty power supply
Bad connection to fuser unit
You will need a service technician to fix this.
Dec 07, 2009 | Savin Office Equipment & Supplies
Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
May 29, 2009 | Ricoh Aficio 450 Copier
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
I Can not Reset error -codes
Its a fuser error code, the machine won't go back to working unless you go into svc mode and clear the error. I suggest calling a local tech.
Jan 08, 2008 | Ricoh Aficio 1018D Copier
Computers & Internet Logo
205 people viewed this question
Alun Cox
David Payne
David Payne
