Question about Kitchen Ranges
A glass jar fell from the fridge onto the stove and knocked a pan of water over. water went all over and despite being dried the ignition clicked constantly and now we have had to disconnect the electric. how do we stop it because it can't still be wet??
  • 833 Answers
Yes, it can. Some of these items are 'sealed' and can contain the liquid for an extended period. Turn off the power and disconnect the leads to each valve except one. Re-power and see if that's the offender. Keep reconnecting until you find the problem. Make sure that the power is off when making new connections.
Posted on Mar 07, 2008
How can I clear a blockage in the water drain tube ?
Alastair Stuart ... hello,
Model, make... makes for better answers!
Most home use refrigerator (plastic) pans will simply pull out the front with a little gentle maneuvering... for cleaning purposes.
Our little MARVEL is more industrial... it has a small metal pan
and needs to be unbolted before it will come out... so in general yes...
Just keep in mind despite their size and weight
most refrigerators are pretty fragile.
I would try lots of warm soapy water and even air duster cans (compressed air)... before doing any serious surgery from the south end.
Dried milk, ice cream, pudding.... food can form a pretty good PLUG.
Good lick... stuck drains are no fun!
Fir your viewing pleasure...
Cleaning Fridge Defrost Drain
Mar 10, 2016 | Refrigerators
How do you fix phones that fell in water?
try using a hair dryer on low setting on phone to dry it out and placing the phone in a jar for a while with raw rice. Electronics and water do not mix so it may not work you may have damaged circuitry beyond repair.
Jun 02, 2014 | Cell Phones
Blown engine after shop repaired intake gasket valve
They probably got coolant in the oil(easy to do when replacing the intake gaskets) and didn't change the oil before starting it up.Water will always sink to the bottom of the oil pan(denser than oil).If it hasn't been worked on since it "blew",drain the oil into a spotlessly clean drain pan(you might want to capture the dirst oil out of the pan in a glass jar so you can check it for water in the oil).If you find water/coolant in the oil,then the shop that did the intake gaskets is at fault.
Apr 02, 2014 | 1998 Chevrolet C2500 Suburban Instrument...
How should I store my cast iron skillet?
You should store it without the lid. If you leave the lid on then it is more likelt to rust. Some people even put a paper towel inside to protect against moisture. I leave a paper towel in all my pans.
Jan 16, 2013 | Home
Condensation is forming on the glass door and dripping onto floor boards. How do we stop the condensation. It does say to empty drain tray but we cannot find it and instruction manual does not tell you...
The drain tray is under the fridge often times set back a little bit. Remove the kick plate by pulling from one side then the other side, strait forward till it pops off. The kick plate is a plate as close to the floor as you can get on the front side of the fridge going the entire width of the bottom of the fridge. Now get eye level with the underneath of the fridge. Center your view on the underneath of the fridge. The drain tray is right there. Pull it out, carefully as it is probably full of water, and dump the water out of it. Replace the drain tray and then replace the kick plate. Check the drain pan once a week or so and you should have no more water leaking on your floor. Hope this helps.
Mar 22, 2011 | Refrigerators
Drip pan is full and overflowing onto floor
If the temperture behind the compressor is not so hot the water will not evaperate. the heat from the compressor dry out the water.
Jan 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 22, 2009 | Frigidaire FRT18FS6C Top Freezer...
Fridge 102H, R600a now about 12 yrs old leaks water onto floor. I have checked the outlet pipe from the fridge and the receiving dish. The pipe is clear. The receiving dish has water in it although it...
The pan will continue to have water in it. The defrost system water drips in the pan where it is evaporated by the condenser fan blowing on it.
Does this pan overflow? Is the water on the floor coming from this pan? Or could it be coming from the water inlet valve where the water supply comes in? Does the water come out the freezer or fridge door at the bottom?
Aug 25, 2009 | Refrigerators
Stove top ignition
I have a Kitchenaid Model KGCT365x and need to replace the igniter switch on the front right burner. Can this be done through the knock hole or does the whol glass top have to be removed? If it has to be removed, what is the best procedure to do this?
Jan 01, 2008 | Bosch HES 252/ HES 256 Electric Kitchen...
Fridge is leaking water all over the place.
The defrost drain opening or drain hose is plugged up with ice or crud. If the drip pan is bone dry, it's a sure sign that the drain opening or drain hose is clogged. Trace the drain hose back to see where it pick up the condensate in the refrigerator cabinet. Remove whatever pieces you need to to clean that sucker out. Door gaskets are torn or not making good contact with the cabinet. No? Well then where's all that water coming from, Einstein? It can only come from the humidity in the outside air--your fridge can't make water, dontcha know
May 10, 2006 | Maytag MBF2256H Bottom Freezer...
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
