Default value changes
How to change a Default Value for a Microsoft Access Field by using script
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
Http://www.functionx.com/vbaccess/articles/defaultvalues.htm
Posted on Mar 10, 2008
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
Tip
Changing Default Location For Installing Apps.
As the size of hard drives increase, more people are using partitions to separate and store groups of files.
XP uses the C:\Program Files directory as the default base direstory into which new programs are installed. However, you can change the default installation drive and/ or directory by using a Registry hack.
Go to :-
- Start > Run
- Type "regedit" (without '' " NOOBS!)
- Go to this Directory...
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
- Look for the value named ProgramFilesDir. by default,this value will be C:\Program Files. Edit the value to any valid drive or folder and XP will use that new locations as the default installation directory for new programs.
on Jan 06, 2010 | Computers & Internet
Tip
Change The Default Location For Installing Apps
 As the size of hardrives increase, more people are using partitions to seperate and store groups of files.
XP uses the C:\Program Files directory as the default base directory into which new programs are installed. However, you can change the default installation drive and/ or directory by using a Registry hack.
Run the Registry Editor (regedit)and go to
Look for the value named ProgramFilesDir. by default,this value will be C:\Program Files. Edit the value to any valid drive or folder and XP will use that new location as the default installation directory for new programs.
on Dec 03, 2009 | Computers & Internet
CAPS WORK BUT LIGHT DOES NOT COME ON
Step 1:
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up. You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2. Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock. Create a Num Lock Script Configure a script that runs to automatically change the Num Lock state. Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code "set WshShell = CreateObject("WScript.Shell") WshShell.SendKeys "{NUMLOCK}" Save the file as "numlock.vbs," including the quotes to change the notepad file to a script. Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default. For a single user, copy it to their startup folder instead of All Users. Enter the BIOS Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings. Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS. Common keys include "F1," "F2," "Del," "ESC" or "F10." Consult your computer's documentation for specifics. Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot. Enable in Linux Linux is an alternate operating system. While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux. Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
http://support.microsoft.com/kb/314879 How do I enable the NUM LOCK key for the logon screen http://support.microsoft.com/kb/154529
Feb 25, 2013 | HP Pavilion Computers & Internet
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
Tip
Disable the Disk Cleanup Warning
If your hard disk has what XP decides is too little space left on it, the operating system will pop up a warning and recommend that you run Disk Cleanup. But you may be like me and not want a virtual nanny nagging you to clean up your mess. You can turn off the warning with a Registry hack. Run the Registry Editor and go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer. Create a DWORD value called NoLowDiskSpaceChecks and give it a value of 1. Exit the Registry and reboot. You can also do this by using TweakUI
Change the Default Location for Installing Programs
XP uses the C:\Program Files directory as the default base directory into which new programs are installed. However, you can change the default installation drive and/or directory by using a Registry hack. Run the Registry Editor and go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion. Look for the value named ProgramFilesDir. By default, the value will be C:\Program Files. Edit the value to any valid drive or folder; XP will use that new location as the default installation directory for new programs.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
I"m connected to a 802.11g wireless network.i
The Advanced Wireless Settings on a Linksys Dual-Band Wireless A+G Router allow you to customize different options and optimize your wireless network's performance. Linksys, however, does not recommend changing the advance wireless settings of the router. The current settings have been configured to optimize the router's wireless performance.
Accessing the Advanced Wireless Settings
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Wireless then click Advanced Wireless Settings.
4418-001.pngNOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
The Advanced Wireless Settings window should appear. Here are some details:
4418-003.pngWireless-A Settings:
  • Authentication Type
    The default is set to Open System. For the Open System authentication, the sender and the recipient do not use a network key (wireless password) for authentication. For Shared Key authentication, the sender and recipient use a network key for authentication. If you want to use only a Shared Key authentication, select Shared Key.
  • Transmission Rate
    The default setting is Auto. The rate of data transmission should be set depending on the speed of your wireless network. You can select from a range of transmission speeds or keep the default setting, Auto. This will automatically prompt the router to use the fastest possible data rate and enable the Auto-Fallback feature. Auto-Fallback will negotiate the best possible connection speed between the router and a wireless client.
  • Transmission Power
    The greater the transmission power used, the larger the area a wireless network covers. To minimize the likelihood of eavesdropping by unauthorized wireless users, do not use more transmission power than necessary to cover the range needed by your wireless network. Try using the router at different levels of transmission power and determine how much power is needed to reach the wireless client, such as a PC or an access point that is farthest from the router. Then select the appropriate level, Full (Default), Half, Quarter, Eighth, or Min, from the drop-down menu. The default setting is Full (Default).
  • Frame Burst Mode
    Allows packet or information bursting which will increase overall network speed.
  • Beacon Interval
    This value indicates the frequency interval of the beacon. A beacon is a packet broadcast by the router to keep the network synchronized.
  • DTIM Interval
    This value indicates the interval of the Delivery Traffic Indication Message (DTIM). A DTIM field is a countdown field informing PC's in the network of the next window for listening to broadcast and multicast messages. The default value is set to one.
  • Fragmentation Threshold
    This value indicates how much of the router's resources are devoted to recovering packet errors. The default value is 2347 and should remain as such unless you encounter inconsistent data flow. In the event you encounter inconsistent data, only minor modifications are recommended.
  • RTS Threshold
    This value should remain at its default settings of 2346. Should you encounter inconsistent data flow, only minor modifications are recommended.
Wireless-G Settings:
    The default is set to Open System. For Open System authentication, the sender and the recipient do not use a network key (wireless password) for authentication. For Shared Key authentication, the sender and recipient use a network key for authentication. If you want to use only a Shared Key authentication, select Shared Key.
  • Basic Rate
    The basic transfer rates should be set according to the speed of your wireless network and the value is set to Default. Depending on the wireless mode you have selected, a default set of supported data rates will be selected. The default setting will ensure maximum compatibility with all devices. You may also choose to enable all data rates by selecting All. For compatibility with products older than Wireless-B devices, select 1-2Mbps.
  • Transmission Rate
  • CTS Protection
    The default value is set to Disabled. When set to Auto, a protection mechanism will ensure that your Wireless-B devices will connect to the Wireless-G Router when many Wireless-G devices are present. However, the efficiency of your Wireless-G devices may be decreased.
  • Frame Burst
  • Beacon Interval
  • DTIM Interval
  • RTS Threshold
NOTE: The features may vary depending on the version number of your wireless dual-band router.
Oct 30, 2010 | Linksys Wireless-G WRT54G Router
Code 800700002how to fix this code
The issue or problem is caused by system drive letter has change or a software has changed the default security provider without knowledge of users.
To resolve the issue, change the system drive letter to revert it back to original value, or match the new drive letter to the security provider. If the default security provider has been changed, reset the default security provider in Windows XP by deleting the relevant keys in the registry.
Reset the Default Security Provider in Windows XP
Start the computer. Press the F8 key during startup to start the computer in Safe mode.
Start Registry Editor (Regedt32.exe).
Delete the following registry keys in the Windows registry:HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\Providers
HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
Quit Registry Editor.
Restart the computer.
Match the Default Security Provider to New Drive Letter
Run Registry Editor (Regedit.exe).
Navigate to the following registry key:HKEY_LOCAL_MACHINE\Software\Microsoft\Cryptography\Defaults\Provider
You will see a few Provider key beneath the branch. In each Provider key, edit the Image Path value to match the new drive letter.
Exit Registry Editor.
Restart computer.
Reset the Drive Letter of the System Drive
Use Registry Editor to change the drive letter of the system drive back to its original value. Edit the following registry key to change the value of the system drive:
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
where \DosDevices\C: and other values presents the drive letters.
Nov 12, 2009 | Microsoft Windows XP Home Edition
Installation path change
Change The Default Location For Installing Apps -----------------------------------------------
Go to :-
- Start > Run
- Type “regedit” (without “” NOOBS!)
- Go to this directory… HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
- Look for the value named ProgramFilesDir. by default,this value will be C:\Program Files. Edit the value to any valid drive or folder and XP will use that new location as the default installation directory for new programs.
Oct 19, 2008 | Computers & Internet
Conversion of nemeric value
If you just want to change the format to text in a query, you can use the Str function in your query. In MS Access, in the Field area of your query in Design View, you can type the following:
YourDesiredCharFieldName: Str([YourNumericFieldName]).
On the other hand, if you prefer to convert the data once and for all in your table, you can go to the Table Design View for that Table, change the Data Type of your numeric field to "Text", and close that window to save the changes. This will convert all of your data in that field from numeric to text permanently.
Jul 01, 2008 | Microsoft Office Access 2003 (077-02871)...
Computers & Internet Logo
David Payne
David Payne
