Question about Dyson Flowcheck CRO1 Front Load Washer
Fills and drains straight away
My dyson washing machine fills and drains without washing displaying fault no 70 600 2701
  • Anonymous Oct 02, 2008
    there was a power outage and when it came back, the machine wont start.
    It displays 70 600 2701 on the display
    we had a power outage and when it was fixed, the machine door was locked. the code on the display is 70 600 2701
    Problem Solver:
  • 12 Answers
The only thing i can think of is your drain hose is lower then the actual drain hookup. Raise the hose higher than the top of the macine .
EEggman
Posted on Mar 10, 2008
The washing machine fills constant and water drains out straight away.
your drain hose is installed incorrectly. it rise at least 36" or so (preferably higher) before it enters the stand pipe (drain pipe connected to the houses plumbing), and there has to be an air break (i.e., not sealed off where the drain hose enters the stand pipe). hope this helps.
Mar 06, 2011 | Washing Machines
The water starts to go in but drains straight away.
If the drain hose is too low and below water level the water has no reason to stay in the machine, and will flow straight through. If the water is pumping out during fill, you have a technical problem....Good luck....Nomess
May 20, 2010 | Washing Machines
Hi, my Simpson eziset 605 doesn't hold any water. It fills and drains straight out then flashes and beeps HC on the display. Any ideas why?
check that the drain hose is not lower than the water level. If it is, the water will simply drain away by gravity.....Nomess
Apr 19, 2010 | Washing Machines
How to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Bosch dishwasher regularly floods
fault is with dishwasher. even if drain blocked, would not cause overfill.
possibly the pipe to sump from fill mechanism partially blocked
Jul 18, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Washing machine displays E30
I have just had the same fault on a ZWF1631W machine. The machine overfills and goes straight to drain.
The level is controlled by an air pressure switch.
Remove the machine top, the switch is the round white plastic one. On mine, one of the wires had broken off. I had to replace the connector with .25" crimps.
If not, the switch may need replacing.
Sparks
Mar 07, 2008 | Zanussi ZWF1630 Front Load Washer
Dyson showing fault no 70 600 2701
hi
the support number for Dyson is 0870 600 2701
this is when the code was obtained, therfor you should have an Fxx code.
Try this:
  1. Switch off the power using the 'MAINS ON/OFF' button
  2. Press and hold the 'Temperature' button
  3. Carry out the next three steps within 3 seconds;
  4. Switch on the power
  5. Release the 'Temperature' button
  6. Press the 'Soil type' button
  7. Check that a message similar to "DIAGNOSTIC MODE 123F7F2F5V127" is displayed. If it is not, repeat from the beginning
  8. Switch off the power
  9. Switch on the power. The fault code should have cleared
Mar 07, 2008 | Washing Machines
Dyson Flowcheck CRO1 Front Load Washer Logo
120 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
