5650 deskjet printer
My hp 5650 deskjet does not print.Ink has been refilled,lights are on.Cannot even print test page
  • 537 Answers
Check to make sure the ink is not dried on the output surface of the cartridge. If problems persist, try a non refilled cartridge to see if the problem can be reproduced there.
Posted on Mar 08, 2008
HP cartrdges are 'BubbleJet'
that is the jets arer part of the cartridge.
These can Block, especially in warm climates.
Take cartrisge out.
Moisten a tissue with water-with some alcahol in its if available
stand the cartridge in it with the jets in the damp tissue for 24 hours
Then re try
Come back if still in trouble
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
My HP Deskjet 5650 will not print in color even though i have installed a new cartridge yet the test page is in color??
Just check your printing property and choose color print and apply the settings and then ok.
Good Luck
Feb 26, 2011 | HP DeskJet 5650 InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
I have a f4480 hp deskjet. How do you reset settings when you refill the ink (black) cartridge? Because even after injecting the ink, I still get the exclamation mark and orange light. And when even...
Some Hp printers, like Epson, require the cartridge to be reset. There is a chip on the cartridge that needs resetting.
This might work;
Place the HP 60 cartridge on a covered surface so that the metal contacts on the cartridge are facing you. Put tape over the top metal contact in the second column from the left-hand side, making sure the other contacts do not get covered. Put the HP 60 cartridge back into the HP printer. Print a test page when prompted. Take the cartridge out of the printer. Leave the tape on the contact that is already covered and also cover the top contact in the column at the far right, making sure no other contact gets covered in the process. Return the cartridge to the printer again. Print a test page. Remove the cartridge from the printer again, remove the tape from the metal contacts, and return the cartridge to the printer. Print the test page and the printer should read the cartridge as full.
Jun 18, 2017 | HP F4480 All-In-One Printer
Hp deskjet 5650 printer is printing A test page after every print job I do. I've tried system shutdowns restarts and turning the printer on and off.
It might be prinitng the alignment sheet because you might have replaced the cartridges receently. So pleae scan that sheet once to complete the alignment and I believe it will fix the issue.
If your issue gets fixed, please come again to give us a
vote which will really motivate me to help people in
future.
May 10, 2010 | Office Equipment & Supplies
Printer does not print though properly connected
Hello there... Please check it's ink level. If it already has run out of ink then you replace the ink cartridge with a new one or refill it (refill is not advised to under warranty printers). Hope this helps. More questions, pls reply here... Ai-ai :)
Dec 03, 2009 | HP DeskJet 5650 InkJet Printer
Ink levels not real
Make sure they aren't refills. One of my HP printers never acknowledged refill quantities.
Oct 04, 2008 | HP DeskJet 5650 InkJet Printer
Hp deskjet 5650 inkjet printer
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Dec 22, 2007 | HP DeskJet 5650 InkJet Printer
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
