The Picture is about 3 inches off. It is not in alinment with the TV. At the bottom of the screen (or picture(3 inches from the bottom of the screen)) the picture bends in about 1 half inch. I cant seem to adjust it in the set up. The TV is a 40 inch screen I think! Model # SD-P5183-K What do I do and how do I fix it? What parts do I need and where can I get them?
  • mattutu78 Mar 07, 2008
    I do not have the manual for the SD-P5183-K any ideas?
  • 790 Answers
Hello sir,
Try entering into service menu according to the manual and make it to deafult!!
Posted on Mar 07, 2008
    Genius:
  • 1,665 Answers
Capacitors failure at vertical deflection section.
Emerson 32 inch lcd tv there is a pure white line 3 inches high on the bottom of the picture.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 28, 2016 | Emerson Televison & Video
Shrunken picture
HI!
can you take a picture to your tv to see exactly what happen to your vertical problem!? then you can post here thanks!
Nov 02, 2007 | Proscan PS56670 56" Rear Projection...
I have purchased a Samsung Led 50 inches tv in USA, The picture is not displayed full on the screen. Can you please suggest?
These are generic instructions for all TV's and all Remotes:
1. Press 'Menu' key on Remote (or 'Setup' key).
2. Go to Setup, View, or Picture tab (whichever one you've got in your Remote's Menu or Setup)
3. Change your Zoom or View aspect.
NOTE: Depending on the dimensions of your TV, you simply may not be able to view the entire picture using a correct aspect ratio (NOT stretched). On my 42" RCA is use a 4:3 Zoom setting to fill my screen but, it chops a little bit off the top & bottom. It's the best I can do with my current setup.
Dec 17, 2014 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
I have a series of colored lines on the right 3 inches of the picture. Lines are vertical(top to bottom).The rest of the picture is fine.There is no picture only lines on the right 3 inches of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 10, 2014 | Toshiba 40RF350U 40 in. LCD TV
Hello, pretty simple probably. How do I use the entire screen for the picture, I can hardly read the news scrolls that come at the bottom of the screen cuz of the 3 inches of black border all the way...
No.Some u can't changes the tv picture on the screen sizes,because depending the bandwith of ur tv are recieving.Most u can changes the tv on picture to wider screen or to fit the whole tv screen.U have the tv original remote wright?Yes.Look a button that said like Viewmode,Aspect Ratio,Picture sizes,Zoomming.Pushes one of these name buttons u will able to changes tv on screen pictures sizes.
Aug 23, 2011 | Vizio 42 in. LCD TV
Cannot get full screen picture. seems like I still have a 36 inch tv. It is a 42 inch LG plasma hdtv
It seems like you're expecting a 16:9 ratio picture. If you're sending a 4:3 ratio signal to the TV, you'll get a 4:3 ratio picture. An option would be to use the remote and set the TV to a 16:9 ratio picture, but that'll stretch the picture and make everything look fat. Another option would be to use the remote and zoom in, but that'll chop off the top/bottom of the picture a bit. Either case would be annoying. Some make matters even more annoying, some programs are broadcasted in a 16:9 ratio signal, but the actual picture is really 4:3 ratio. So...... as long as the pictures don't look skinny, fat, or chopped off, just accept it. If you're really that picky, just watch new Blu Ray movies only.
Jul 22, 2011 | LG Televison & Video
Screen is red and I cannot adjust it enough to get the red out
Problem is going to be in the Green and Blue Tube ,you need to change the Coolant Fuild out and out in New,Philips is well known for having Bad Coolant fuild in the G/B Tubes.
With Back Off and TV on Look down inside of each Tube you should be able to see a Clear picture, in each Tube, If you do Not then you need to change out the coolant fuild.
You also have a Screen/Focus Control Block, it controls the Screen Drive and Focus to Each Tube R/G/B 3 controls on top and 3 below them. Top 3 should be for Focuse and Bottom 3 Screen Drive /Brightness to each Tube.
Now in order to aline for Correct Color you will need to adjust all 3 Tubes , Turn Color OFF in Menu then aline the Tubes untill you have a Black and white Picture ,Then go back to menu and turn Color on.
Mar 01, 2011 | Philips 51PW9303 51" Rear Projection...
Do not have copy of owners manuals and user guides
Problem is likely with a setting at the picture source. Make sure you only have enabled the setting your TV is capable of (480i, 480p, 1080i, etc)
Apr 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
Picture only in middle of screen
Sounds like vertical problems on your circuit board. Unless you have some electronics experience you'd better take it in for repair.
The inside of a tube TV contains high voltages even when off and unplugged.
GL
Oct 04, 2008 | Toshiba 36A50 36" TV
Vertical section problem
I have found an fix for this a capacitor 2494 needs to replaced.
Aug 21, 2008 | Philips 27MT3305 27" TV
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
