Dyson showing fault no 70 600 2701
My dyson washing machine fills and then drains straight away displaying fault number 70 600 2701
  • 123 Answers
Hi
the support number for Dyson is 0870 600 2701
this is when the code was obtained, therfor you should have an Fxx code.
Try this:
  1. Switch off the power using the 'MAINS ON/OFF' button
  2. Press and hold the 'Temperature' button
  3. Carry out the next three steps within 3 seconds;
  4. Switch on the power
  5. Release the 'Temperature' button
  6. Press the 'Soil type' button
  7. Check that a message similar to "DIAGNOSTIC MODE 123F7F2F5V127" is displayed. If it is not, repeat from the beginning
  8. Switch off the power
  9. Switch on the power. The fault code should have cleared
Posted on Mar 07, 2008
  • Sam Stothers
    Sam Stothers May 19, 2011
    yes this cleared the code but can you help
    when i turn machine on and start a wash it fills but stops and code comes back
2 Suggested Answers
  • 12 Answers
SOURCE: fills and drains straight away
The only thing i can think of is your drain hose is lower then the actual drain hookup. Raise the hose higher than the top of the macine .
EEggman
Posted on Mar 10, 2008
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
F15 I KNOW WHEN FIRST SWITCH IT ON THERE IS A COUPLE OF BUTTONS TO PRESS TO OVER RIDE IT JUST CANNOT REMEMBER WHICH BUTTONS DO U KNOW?
to clear fault f15 turn off the machine hold down the temperature button turn on the power release the temp button then in less than about three seconds press the soil button.a diagnostic screen will come up on the display it will display a set of numbers these indicate the number of wash cycles and the most recent fault codes followed by the software version of the computer once you have this displayed turn off the power then turn it on again the fault should have cleared if the fault code reappears you will need to contact Dyson to repair your machine
Aug 15, 2010 | Dyson Flowcheck CRO1 Front Load Washer
The water starts to go in but drains straight away.
If the drain hose is too low and below water level the water has no reason to stay in the machine, and will flow straight through. If the water is pumping out during fill, you have a technical problem....Good luck....Nomess
May 20, 2010 | Washing Machines
Hi, my Simpson eziset 605 doesn't hold any water. It fills and drains straight out then flashes and beeps HC on the display. Any ideas why?
check that the drain hose is not lower than the water level. If it is, the water will simply drain away by gravity.....Nomess
Apr 19, 2010 | Washing Machines
How to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Machine filling and then immediately draining
Hi You need to higher your outlet pipe on the back of the machine there is usually a clip to hold the pipe in place 3/4 of the way up the machine so it looks like a u upside down its should stop the machine from emptying straight away
Apr 29, 2008 | Zanussi ZWF1430W Front Load Washer
Washing machine displays E30
I have just had the same fault on a ZWF1631W machine. The machine overfills and goes straight to drain.
The level is controlled by an air pressure switch.
Remove the machine top, the switch is the round white plastic one. On mine, one of the wires had broken off. I had to replace the connector with .25" crimps.
If not, the switch may need replacing.
Sparks
Mar 07, 2008 | Zanussi ZWF1630 Front Load Washer
Fills and drains straight away
EEggman
Mar 07, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Washing Machines Logo
400 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
