Question about Canon I990 InkJet Photo Printer
IP1880 Canon PIXMA showing Ink absorber full
I've a IP1880 Canon PIXMA printer.The printer is showing Ink absorber full. we ave changed the cartridge also, but the result is same. I've only one printer & the work load is immense. PLease Help!!
  • 1 more comment
  • Anonymous Mar 12, 2008
    Ink absorber full error message on Canon ip6310D printer...
    Alarm is flashing, won't print.
  • Anonymous Mar 22, 2008
    ink absorber is full i have change the ink cartrage but still the same it wont print
  • Anonymous Apr 29, 2008
    where is the INk absorber at in this prniter. I cant find it.
Pixma ip 1880 is full(solution)
1. first unplug power cable and usb cable
2. hold power for 1-2 minutes
3. turn on power
4. your printer should back to normal printing
Posted on Mar 21, 2009
It was a good idea but still it is full what can i do is it really in the cartridge located the ink absorber?
Posted on Aug 20, 2009
It is a common issue with most canon printers.....So the advice i like to share with u is,first u need to empty the waste ink tank absorber on the printer and would like to let u know that changing to a new cartridge would not solve this problem as this has something to do with the printer and not the cartridge.
So once u empty the waste ink tank absorber (something similar to a small sponge..ie: it is the place where your excess ink goes. U should take off that ink as it has reached the maximum point of absorbing and it's unable to absorb more ink) your printer should work fine.
Hope this helps.
Posted on Feb 11, 2009
  • Canon Master
  • 525 Answers
Follow this procedure:
1. Enter Service Mode: Hold Power button and plug a power cord, then push Resume button twice and release all buttons.
2. Free Download from Internet: GeneralTools for Canon Pixma IP1880
3. Starting GeneralTools
4. CHANGE USB PORT change into PORT of your printer
5. click lock release
6. click ip1800
7. click device id
8. clear waste ink counter by clicking MAIN & PLATEN
9. Check EEPROM Box
10. Click EEPROM Dump
Power off printer and all done. Work again!
Posted on Jan 14, 2015
Why is my canon ip1800 printer still not printing after cleaning the ink absorber, I still get the message ink absorber is full
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The ink absorber is full Canon Pixma IP1980 IP1880
How to Clean Canon Ink Absorber
iP1800 ink absorber
Apr 07, 2016 | Canon Office Equipment & Supplies
Canon MP160 Printer "Ink Absorber is Full
Canon MP160 PIXMA shows ink cartridge full. How do I empty...as I just refilled with new cartridge, due to stating no ink. Please help..thank you.
Mar 12, 2013 | Canon PIXMA MP160 All-In-One InkJet...
My canon ip1880 's ink absorber is full
Ink absorber is a part of the printer that absorbs the excess ink while printing. There is a way to reset it but its not recommended, as the ink will eventually leak into the printer. I suggest that you get a replacement ink absorber pad from canon and replace the one in your set.
Nov 10, 2010 | Canon Office Equipment & Supplies
Pixma ip1880 ink absorber is full pls tell how to fix
Turn off the printer and take some soft absorbent tissues and fold it into a pad.
Lift the cover to expose the ink cartridges and place this pad over the ink absorber on the LHS of the printer so the pad soaks up the wet ink.
Repeat until the absorber is nearly dry.
Nov 24, 2009 | Canon PIXMA MX310 All-In-One Printer
How to remove ink in th full ink absorber?
waste ink absorber error message can sometimes be solved by resetting the printer itself. i havent yet tried in ip1880 but in ip1200, th e resetting method is this: (it might also work on other models)
1. unplug the power cord and the data cable(printer to pc) 2. while press-holding the (printer) power button plug the power cable (do not release printer power button until step 3) 3. press 'resumet' ( the button below the power button of the printer) button twice... 4. release the power button 5. connect the usb cable of the printer to the pc... - a new canon printer shall be found in the list of printers. use it as default printer
Aug 07, 2009 | Canon PIXMA iP1800 Printer
Cannot print documents
replace ink catridge. wash with alcohol just only the head print. then place it. turn on printer without conect with ur pc. pres botton reset hold 3-5 minutes. then conect to pc. enjoy it
Apr 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 printer won't print.
My Canon PIXMA iP1880 cannot print...and shows a message "ink absorber is full" can u help me this problem..
Mar 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jan 15, 2008 | Office Equipment & Supplies
Canon I990 InkJet Photo Printer Logo
4,734 people viewed this question
old marine
old marine
