Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Printer MFC440 cn not reponding to wireless PC
My MFC440 cn is not responding when I try to print from the wireless computer although I have followed instructions in the manual carefully- I installed the cd it came with in the main computer and also in the wireless- whenever I am ready to print it allows me to choose a printer but when I do there is no response- However the printer works from the main PC-
Thanks for your attention to the matter-
eddy b
  • Barry Gardner
    Barry Gardner May 11, 2010
    What Operating Systems (Win98, XP etc.) are on the PC's?
    Do you get any error messages at all?
    Can you see the printer in the 'Control Panel' 'Printers' on the PC using wireless, and does it indicate 'Ready' ?
  • 832 Answers
You might find answers here:
http://welcome.solutions.brother.com/bsc/Public_s/index.html
choose your country and then your mfc. go to faq/network
Posted on Mar 07, 2008
Sorry I was wrong about the number on the computer but the question is the same how come I can't print or fax ?
Do you receive any type of error message? It seems for some reason your wireless printer is not communicating with the PC/laptop. Also, printing and faxing each require different forms of communication. In printing, you PC is just telling the printer to print what is on the screen; faxing requires the use of a phone line that needs to be set-up properly. Although the wireless setup btw the printer and PC must be working first.
Try uninstalling and reinstalling the software with the printer not plugged into the PC until the software is installed. Also, reread your manual carefully for insights about your issue.
Mar 25, 2015 | Dell All-In-One Wireless Printer V515w -...
2490MF
Check that you do not have a firewall working. Set the printer by inputting the Ip or printer name when installing, do not browse for printer.
Aug 21, 2008 | Konica Minolta magicolor 2490MF Laser...
Why when wireless printing using same hardware worked fine, now not responding.
Unless it is the EXACT same wireless router from your service provider it could be the router. I mean that if you have moved and your provider gave you another router (same make and model) then it could be the wireless router. I struggled with this myself and after having the provider change the router, the problem disappeared immediately with the printer connection. The problem was only with the printer (HP in this case) as other wireless devices worked okay. Strange but true.
Sep 09, 2014 | Canon MG3170 INKJET COLOR ALL-IN-ONE...
How to make a printer wireless
Plug into a wireless print server.If your printer has a USB port, you can plug in a wireless print server, a small box into which you can connect your printer. The advantage of investing in a print server is that you don't have to connect the printer to a PC, which means you can use your laptop and print anywhere in your home.
.tmnAdsenseContainer{margin-bottom:10px;} We found plenty of print servers in the $50 range on Newegg.com, although many of the models cost closer to $75 or $100). Before you buy, make sure the print server is compatible with your printer (the printer's written materials are less likely to specify compatibility with print servers).
During the setup, you will have to plug the printer into the printer server, and connect that to the router using an Ethernet cable. Meanwhile, you'll have to install software on your computer and configure the connection, as you would when setting up a router.
also try this link will help you
http://www.makeuseof.com/tag/printer-wireless/http://www.ehow.com/how_4530941_make-printer-wireless.html
http://www.labnol.org/gadgets/make-wired-printer-wireless/12639/
Dec 27, 2012 | Samsung Office Equipment & Supplies
Printer not responding to PCs print instruction All cable connections checked and appear firm in outlets. Will not print either new or existing files
Are you able to make copy from printer or print test page ?
If you are not able to make copy from printer or print self test page
Check if the cartridges are not empty.
If they have ink, follow the steps below
1. Disconnect the power cable from back of printer
2. While holding the # and 6 button on front panel of printer connect the power cord to printer.
* Note : This is semifull reset and this will erase fax logs and any wireless settings on the printer.
You will have to re-setup the printer on wireless network.
Or if the copy works fine from printer and you are not able to print from PC only, follow the solution below.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 29, 2010 | HP OfficeJet 7140xi All-In-One InkJet...
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
Wireless printer won't print wirelessly.
Has the printer software been installed on the computer? Have you added the printer to your printer list on the computer?
Aug 24, 2009 | HP Photosmart 3310 Printer
I need an operation manual on a brother,advantage MFC440 CN copier, printer
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Apr 19, 2009 | Brother Multi-Function Center MFC-240C...
Font size-printing
Hello Christina,
There are two sections to look into. 1) Device Settings. 2) Printing Preferences.
Between the two, I confident that you can find the solutions.
Aug 06, 2008 | Brother MultiFunction Center MFC-440CN...
Print server
Hi I have found a link below that will assist ya to set it up all right... http://tech.yahoo.com/gd/adding-a-wireless-print- server-to-your-network/200458 Ya must ensure ya have the drivers on ALL the "Client" computers... IE: install ya "Drivers" on each PC...
Sep 18, 2007 | Linksys Wireless-G WRT54G Router
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
236 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
