Question about Microsoft Windows XP Professional for PC
Memory dump Hello Sir, I have a problem with my pc because its memory dumps with every 10-15 minuets interval, sometimes it dumps while booting. What should i do to fix this problem? Should i change my hard disk?
    Guru:
  • 55 Answers
A small memory dump file records the smallest set of useful information that may help identify why your computer has stopped unexpectedly. This option requires a paging file of at least 2 megabytes (MB) on the boot volume. On computers that are running Microsoft Windows 2000 or later, Windows create a new file every time your computer stops unexpectedly. A history of these files is stored in a folder.
This dump file type includes the following information: • The Stop message and its parameters and other data • A list of loaded drivers • The processor context (PRCB) for the processor that stopped • The process information and kernel context (EPROCESS) for the process that stopped • The process information and kernel context (ETHREAD) for the thread that stopped • The Kernel-mode call stack for the thread that stopped The small memory dump file can be useful when hard disk space is limited. However, because of the limited information that is included, errors that were not directly caused by the thread that was running at the time of the problem may not be discovered by an analysis of this file.
If a second problem occurs and if Windows creates a second small memory dump file, Windows preserves the previous file. Windows gives each file a distinct, date-encoded file name. For example, Mini022900-01.dmp is the first memory dump file that was generated on February 29, 2000. Windows keeps a list of all the small memory dump files in the %SystemRoot%\Minidump folder.
Configure the dump type loadTOCNode(2, 'summary'); To configure startup and recovery options to use the small memory dump file, follow these steps.
Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. Click the Advanced tab, and then click Settings under Startup and Recovery. 4. In the Write debugging information list, click Small memory dump (64k).
To change the folder location for the small memory dump files, type a new path in the Dump File box (or in the Small dump directory box, depending on your version of Windows).
Open the dump file loadTOCNode(2, 'summary'); To open the dump file after the installation is complete, follow these steps: 1. Click Start, click Run, type cmd, and then click OK. 2. Change to the Debugging Tools for Windows folder. To do this, type the following at the command prompt, and then press ENTER: cd c:\program files\debugging tools for windows 3. To load the dump file into a debugger, type one of the following commands, and then press ENTER: windbg -y SymbolPath -i ImagePath -z DumpFilePath kd -y SymbolPath -i ImagePath -z DumpFilePath
Posted on Mar 07, 2008
  • 8,596 Answers
Make sure your computer meets the minimum system requirements for running Windows XP if this is an upgrade - I had a computer that technically met the requirements, but boy did it run slow after I upgraded from Windows ME to Windows XP. If your hard drive contains no programs, information that you can live without, then you can completely reformat the hard drive and start over from scratch. If it does contain important programs, burn them to CD or DVD - and make sure that your computer can read the files after you are done burning - and then reformat your hard drive.
2 Suggested Answers
starcomp
  • 117 Answers
SOURCE: I am getting "Blue screen of death" every 10 minets from startup.
no change your RAM and Format your Hard disk using Disk manager of your hard drive manufacturer
for ex: if you uses segate
in the http://download.seagate.com/seatools/registration.nsf/eula/desktop
or
http://www.seagate.com/www/en-us/support/downloads/seatools/
in this second link you can find the dos version
Blue screen with message ..registry can not find hive file \system root\sytem32\config\softwareor it's alterate.beginning dump of physical memory, physical memory dump complet
Contact Dell support via email, it is free and fairly fast response time, they may have a solution other than reloading the operating system, which I think is what needs to be done.
Jan 26, 2012 | Dell Computers & Internet
Will not boot up past the message I describe below
You might reload your Operating System to correct this. Insert your Recovery disk into your drive, choose DVD as Boot Option, recover your OS.
Nov 22, 2009 | Sony VAIO VGN-FJ270/B Notebook
What is dell l2 cache patern test failure?
cmos problem battry 3v change or bois chip change ok
Nov 11, 2009 | Dell Vostro 1310 Notebook
My son's 5315 will boot up, then hang, do a memory dump, then restart at the screen that asks how you want to start Windows, i.e., safe mode, normally, etc.
hello
If it is showing the memory dumping message then you RAM is dying.
you soon have to replace it with a new one.
If it shows some other error message then please mention.
Thank you
Aug 16, 2009 | Acer Aspire 5315 Notebook
Physical dumping of memory
Hi!
Take out the RAM and clear the fungus..
fix the RAM and start with safe mode....
Bye & Take care...:)
Mar 13, 2009 | Microsoft Computers & Internet
Dump of Physical Memory
Put the Dell CD in the drive bay. Turn on the computer and start pressing <F12> key. It should say "Preparing one-tome boot" When the screen shows a selection menu for the boot device, use the arrow keys to select the CD and press <Enter> key. That should run the Dell CD. Follow the onscreen prompts to run diagnostics checks
Dec 16, 2008 | Dell Inspiron 8600 Notebook
or
Mar 07, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
363 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
