Question about Panasonic Lumix DMC-FZ7 Digital Camera
Camera lens will not extend ...
... took a nasty fall with my beloved camera ... now the lens will extend only a fraction of an inch (a 32nd maybe), the motor makes a little cricket-like sound, and I get a "remove lens capt and press > button" message. ... my guess is it's a goner and it's time to pony up for a new camera ... but I'd like to hear from anyone on a) whether there's something I can do myself or b) whether it's likely repairable at less than, say, half the price of a good used or refurbished replacement ...
  • walterkjazz Mar 10, 2008
    actually, after reading responses to the misleading "remove lens cap" message problems, I was inspired to use a small hex wrench to force pry the lens forward until I could grab it and pull it all the way out. Once pulled out fully, it was, apparently, back on track. It's worked fine since.
  • eewilk01 Mar 20, 2008
    does anyone know how to remove the lens barrel on this camera? i'm having the same problem.
    thanks!
  • 51 Answers
Http://www.instructables.com/id/Repair-Stuck-Lens-on-Panasonic-FZ5/
But be super-careful about taking the big cog off the lens. there are two tiny ribbon cables that snap easily.
Posted on Mar 26, 2008
When I turn off my CoolPix S6 the lens would close completely. When I turn on my camera the lens is completely open and the screen just says lens cover error.
The lens is damaged and needs to be replaced. Sometimes with use or maybe an accidental hit to the lens can cause a malfunction to the camera resulting in that error. Also if you for example took the camera to the beach, getting something like sand in the camera can jam up the lens and prevent it from fully extending or retracting.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_005777b2fc6bfc30
Mar 24, 2011 | Nikon COOLPIX S6 Digital Camera
Camera will not "close"
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 17, 2011 | Canon PowerShot SD960 IS Digital Camera
When the camera is turned on the lens will extend and retract three times shown lens error and then turn off
Dec 19, 2010 | Nikon Coolpix S560 Digital Camera
Lens error occured after taking a few pictures. I
Oct 30, 2010 | Nikon COOLPIX L18 Digital Camera
Lens error lens is jammed i let camera fall could You please give me a contact so that i can use from Northern Ireland
Oct 14, 2010 | Cameras
We have have two Cannon cameras which have had approximately 18 months of use that have presented with the same problem. The lense is completely jammed in the housing. My daughter is currently overseas...
Sep 26, 2010 | Canon Cameras
I have the Canon power shot s2 is digita. I cant
You might have a mecanical problem at the lens. The only way to surely fix this is at a local electronist or Canon dealer. Trying to repair it yourself can render the camera unusable and unrepairable.
Apr 11, 2010 | Canon PowerShot S2 IS Digital Camera
Camera lens is stuck in . Changed the batteries, light goes on but lens starts to come out only a fraction and stops.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 05, 2009 | Cameras
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens cover does not operate correctly
I fixed this problem on my Fuji FinePix A303 (though it took some hard work).
The problem:
Camera Lens Cover stuck open or stuck closed.
Power on, and get !LENS COVER error.
Lens fails to extend.
The solution:
Short answer: The motor driving the lens cover is weak and eventually breaks down. I manually open the cover now. This took a manual modification to the camera (and some work).
1. Take the camera apart. See here for details, and be careful around the flash, as you'll get a nasty shock otherwise! http://www.mathematik.uni-marburg.de/~haim/focuserr.htm
2. Once you can see this, you're just about there:
3. Take off the battery cover (in the picture above).
4. Wrap a wire around the sliding pin for the lens cover, and drill 2 small holes through the black structure underneath the battery case, and then to the outside. The wire goes from the pin to the outside via the two holes. You should be able to manually open and close the camera cover COMPLETELY now with the wire.
5. Reassemble the camera (actually, you can test that it's working when it's all apart, if you're careful).
6. To operate the camera now, close the shutter first while off. Power on the camera, and very soon after open the shutter all the way by pulling on the wire (from step 4). This basically mimics the action of the little lens cover motor. If you timed it right (you have about a second margin), the lens should extend and everything functions perfectly.
It would have been nice to have been able to simply buy a new motor, but that would probably be a pain and cost some money.
Hope this helps!
Matt Van Dyken.
http://mattvd.googlepages.com
Aug 16, 2008 | Cameras
Panasonic Lumix DMC-FZ7 Digital Camera Logo
127 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
