Question about Mitsubishi VS-60111 60" Rear Projection Television
Mitsubishi VS-60111 video problem
I have a problem and need of a help in fixing my TV. It turns on and works for a little while maybe 1 minute. Sound is good and picture is good. I have replaced a resistor that a gecko has died on in the power supply section. I also have resoldered some joints on the convergence ICs. I have a error code of 21. I have checked the capacitors, diodes, and have replaced IC5A02. I can't find a replacement for IC5A00. I am not too sure if I am checking the right components. Once again problem that I have is that my TV turns off after 1 minute of turning on and when there is video. With out any video the TV stays on and I have an error code 21.
  • MWTech Mar 07, 2008
    I have the service manual, but I'm not that great with trying to find out which component need to be replace. I am good in replacing parts, but thoroughly inspection I lack of doing so.
  • ghofman3k Oct 21, 2008
    Same exact problem. Wondering what code 21 is.....
  • Mitsubishi Master
  • 8,617 Answers
You can get the manual at this link emailed to you, and they will provide free support to help you diagnose and find parts
http://servicemanuals.vstore.ca/
Posted on Mar 07, 2008
Tv mitsubishi vs-60111
Was there a power failure? unplug unit for a min and plug it back in. hold power button til unit turns on. If it still flashes you may have a power supply problem inside the unit.
Apr 08, 2014 | Mitsubishi VS-60111 60" Rear Projection...
I have a Mitsubishi VS-60111 TV and the colors are messing up. When I go into the Convergence screen, the blue line is warped and will not let me move it back itno place. What do I need to do?
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Jan 28, 2011 | Mitsubishi VS-60111 60" Rear Projection...
I just wanted to know how much they go for. Mitsubishi big screen tv hd 1080 series model vs-60111
Probably 1500.00 new, but that's an old set. If your trying to sell it I would ask 350.00 for it, if it works.
Dec 18, 2009 | Mitsubishi VS-60111 60" Rear Projection...
My tv is showing blue when i turn it on i think my blue projector light is out?
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Nov 06, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi Big Screen TV Model VS-6051 will not turn on. I hear a clicking sound when I unplug it from the wall but it still does not turn on.I have tried using an alternative power source and it still...
hello VS6051 POWER SUPPLY PULSATES ON/OFF IC9A1(267P062010)
VS6051 VZ2 POOR START L9A30(BEAD ON LEG OF R9A21)-R9A22 TO 1.2K, R9A12 TO 15K,C9A15 TO 330UF
VS6051 VZ2 POOR START,ADD 22UF/100V PARALLEL W/C9A17
VS6051 VZ2 WILL NOT POWER ON D9A00(264P102020) IC9A0(267P112050)
Sep 19, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Tv turns on for about three seconds and then turns
here's a simple test, tap the unit several times and see what happens.but, whatever happens, call a tech,it has already faulty components inside.
May 14, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Flashing Tv screen
Turned out to be a problem with my dish receiver. Found out by attaching a separate DVD unit to the TV, and it didn't flash. I then realized everything ran through the dish receiver. Called them, reset ( by unplugging for 90 seconds) and all was well.
Jul 20, 2008 | Mitsubishi VS-60111 60" Rear Projection...
VS-60111 turns off on its own after few hours
Did you repair the two leads? Ao check near the Convergence ICs for an open resistor or two, although that shouldn't effect your audio. Yu most likely have a low voltage regulator or bad capacitor. You will probably need the service manual to actually track it down. I will post a link where you can ge one for 12.99 and the include free unlimited support. They will also email it instantly to you if you return to the site and send them an email requesting they email it to you. You sound like you could fx it with the service manual and some guidance. Here is the link.
Jan 25, 2008 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi VS-60111 video blink
I would check for Bad solder joints around the flyback, and the verticle and horizontal yoke plugs for starters. Lower your volume and listen if you hear the high voltage come back up when your video comes back up. Let me know what you discover when you check the solder joints.
Jan 05, 2008 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi VS-60111 60" Rear Projection Television Logo
141 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
