Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
My MFC-440CN Everytime I try to print, it says that the computer is off or offline. But, Its registered online and is turned on. What can I do to get it to start printing? Another thing: I have ran out of Cyan Ink(blue) and the machine keeps shoewing hhow to replace it on the screen. Does that play some role in the printer not working?
    Scholar:
  • 104 Answers
Yes, an empty ink cartridge will prevent the printer from functioning.
Not all printers will do this, but the Brother MFC series will not print if any one of the cartridges are empty. Replace the cartridge and all should be fine.
Posted on Mar 07, 2008
How to turn printer from offline to online
Often times the printer will show being offline if the computer wasn't turned on before the printer. Also, if you have more than one printer be sure the printer you are trying to use is selected in the printer setup page.
Aug 16, 2017 | Brother MFC 7860DW - Multifunction fax /...
Printer is showing offline
If you right click on the printers icon, you can then select, ENABLE. That will put the printer online. Also ensure that the printer is turned on too.
Feb 23, 2010 | Brother MultiFunction Center MFC-440CN...
My printer (MFC-440CN) keeps going offline. It's hooked via Ethernet cable to my home network. If I disconnect/reconnect the cable it comes online again but after I print it goes offline again. Thanks...
First, try printing while the printer is directly connected to the computer to see if you will get the same behavior from the printer.
If the printer works fine when directly connected to the computer, reconnect the printer via the Ethernet cable and try to perform the "ping of death" (continues ping of the IP Address of the printer).
Using the continues ping, you will see if the communication between the computer and the printer is being interrupted or not. Here's how to perform the ping of death:
DOS Prompt > ping 10.71.x.x -t > hit enter.
On the DOS prompt, you need to type ping and then hit the space bar, followed by the IP address of the printer > space bar > minus t (-t) > Enter.
____________________________________________________________
If the same problem occurs, then try to uninstall/reinstall the printer driver. If that did not help, try to clear the print spooler on your computer.
Good luck and have a great day!
Jan 08, 2010 | Brother MultiFunction Center MFC-440CN...
My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Nov 10, 2009 | Brother MFC 490cw Color Inkjet...
I have a Brother MFC 440 CN and it's telling my computers that it's offline, so I can't print. I've had other problems with it in the past, including 'Unable to Print' errors and an alignment issue with...
Try going to your control panel then to printers and reset the printer. After you reset the printer reboot the computer and it should work. if not you may have to delet and reinstall the printer on your computer.
Sep 26, 2009 | Brother MFC-440CN InkJet Printer
My Brother MFC 440CN will not print
printer 440cn does not print. you call the printing option and the printer icon star jumping for a while then stop.I then open the printer queue and it is empty. I am running mac OS 10.58 in my Imac
Jun 20, 2009 | Brother MFC-440CN InkJet Printer
After a power outage, my Brother printer,
First off, make sure that you have turned both the printer and the computer off and then turn them on(cycle the power). When you go to the printer in 'printers' be sure that the printer is not light in color, if it is, then it's failed to come back online or it's broken. When you say, 'I have tried going into the control panel and clicking on print offline', I take you to mean 'print online', because you don't want to print offline, you want it online...
The easiest way to solve this is to move the usb plug going into the computer from the printer from one port to another, this will force the computer to re recognize the printer. I see that this printer has network capability. I am assuming, that the printer is connected via USB and not Ethernet. [USB, rectangle the size of your pinky, but narrow, Ethernet looks like a big phone plug]. If you move the plug from one USB slot to another and you don't hear the hardware connect sound(low tone then high tone), then your printer may be broken. It is possible if it is broken that the Ethernet port still works, but using that is beyond this discussion.
Good luck,
Brett
Mar 12, 2009 | Brother MultiFunction Center MFC-440CN...
My MFC-440CN printer has gone offline and how to i get it back online
I had this same problem. What I did was I deleted the printer from the control panel. I then clicked on add a printer and it added the printer back. I printed a test page and it worked fine.
My printer is set up wirelessly on a D-Link router.
Dec 13, 2008 | Brother MultiFunction Center MFC-440CN...
My printer is "offline"
Try disabling the firewall, printing, re-enabling the firewall. My printer keeps working after re-enabling the firewall (at least for a while). Not ideal, but beats reinstalling the printer.
Mar 01, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
217 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
