Question about Panasonic Audio Players & Recorders
Hello I have a 1976 National Panasonic SL18 record player and it seems the motor has worn out as it plays very slowly. Could you suggest what I should do - should I try and buy a new motor or can it be fixed. Thanks John jleary001@hotmail.com
SOURCE: bose cine mate speakers
No it won't be like surround sound, but you'll have the next best thing: a nice, powerful, natural Hi-Fi sound. I have a 46 inch 1080p Sony connected to a Sony Blu-Ray and Bose Cinemate Speakers. No complicated rear speakers wiring, no awkward center speaker to hide. The only drawback is that Bose doesn't have (yet) a code to operate the Blu-ray player with the Cinemate remote control.
Hope this helps to make your decision.
Posted on Apr 04, 2008
  • 151 Answers
SOURCE: I have bought an old
If you cannot see a small tip on the needle then yes it is worn out,but you can check by rubbing your finger over the tip when the system is on,if you hear sound through the speakers then it should play the album,make sure that the weight at the back of the arm is set to keep the needle in the groove as this may be set to far back,move it forward to keep weight on the needle.
hope this helps.
CABLE GUY.
Posted on Jul 16, 2008
jaffa012001
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
SOURCE: remote for panasonic CY-VHD9500U car DVD player
http://www.partstore.com/Part/Matsushita/Panasonic/CYVHD9500U/Matsushita/Panasonic/YEFX9995179/New.aspx
Posted on Aug 14, 2008
ginko
  • 19396 Answers
SOURCE: Hotpoint fridge too cold!!
Hi John,
There had been changes in the system recently, and not all answers are being displayed.
Now I do not know where to find your original problem.
If you find any link to the thread in your old emails, copy and paste it here , so that I can track back the problem.
When fridge is freezing inside that can be caused by:
Bad temperature settings.(temp too high)
Bad climate conditions (very hot outside and fridge set to lowest temp)
Problem with evaporator system at the back of the fridge.
Faulty thermistor, not detecting when temp. is too low.
Compressor problems.
Try moving the fridge from the wall, this sort out many problems with condenser/compressor and evaporator.
If there is Ice inside also remove ice to get back to normal.
If that does not work, it is either the compressor coming to the end of its life, or a faulty thermistor.
I will try to find the original thread, I suggest to complain with fixya, we have had serious disruptins since the new Fixya system started to work.
Posted on Nov 01, 2008
My PTCDS1U just started playing too slowly despite my attempts to adjust the speed
Is this a belt drive turntable? If so, replace the belt - its slipping.
Dec 30, 2013 | Pyle Pro - PTCDS1U - Home Ptcds1u...
Hi. My National RX-CW55 Cassette Recorder-Player/Recorder, although its motor, belts and all 4 motor connection wires are not defective, does not work. Its radio and amplifier system and CD/ Connection...
I have got a Panasonic RX CW55 equal design and only one motor with 4 poleas for mecanism autoreverse, my problem is the quartz timer, no function.. best regard!! don´t speak english good, thanks
Nov 30, 2010 | Kitchen Ranges
The dvd recorder has stopped recognising dvds that previously it would play quite happily. Is the likely cause a dirty lens or is it more likely to be something to do with the spindle? I get the "cannot...
I presume you hade cleaned the discs and the players optical lense before posting this request and also tried them on another player?
Basicaly If they do not work on other players then the discs have now failed for some reason: many budget priced discs I have come across only work for a few years.
If you have a 'spindle problem' then your laser is probably slowly moving off track. If so you should be able to record and then playback on a GOOD disc for a while.
May 27, 2010 | Panasonic DMR-E50 DVD Recorder
Have lost chanel 5 and others on my panasonic dvd recorder since national retune.How do i retune my dvd recorder?
It seems others have had this problem too, but there seems to be a generic solution to it. Unplug the device from the mains and leave it without power for a few minutes. Then, reconnect your device. That should solve your problem.
Back to your question about retuning it, you have to hold the channel up and channel down buttons at the same time for a few seconds. Auto-setup should start.
Hope that helps,
Thomas
Oct 10, 2009 | Panasonic DMR-EH60 DVD Recorder/HDD...
DVD tray won't open
Do you have a problem w/ people to open and close the drive readily? Like little kids or something? B/c It sounds like ur drive motor could have worn/burned out. If that's the case, take it back to Wal-mart(if they have the same one) and exchange it. Wal-mart is an investment. ha ha.. I hope this helps.
   `Nbryson
May 31, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't play recorded discs on other players or computer only DMR-E
TRY FINALIZING THE DISC IN THE SAME UNIT IT WAS RECORDED IN.
Mar 17, 2009 | Panasonic DMR-E55 DVD Recorder
VC recorder keeps on driving
I beleave your sensor that tells the player weather a tape is in there or not needs replaced ~ It sounds like it doesent know the tape is not there aand will not shut down! (replace tape sensor)
Please rate my answer and help keep this site free!
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
HELLO, I have a dvd recorder/vcr recorder by Insignia IS 100121. I would like to know if it can play Region 2 DVDS.
My mv303 karaoke machine words from the song on screen seem to go double image miss letters in the words while reading and singing the song. Is it the cdg itself that is worn out or what is it?
Dec 23, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Panasonic dmr-es15
Pan. DMR-ES15 I WILL NOT RECOGNIZE ANY DISC I PUT IN. WILL NOT PLAY A COMMERCIAL DVD MOVIE. SEEMS TO HAVE STARTED WHEN IT COULDN'T FINALIZE A RECORDED DISC. HOW TO RESET?
Oct 28, 2007 | Panasonic DMR-ES10 DVD Recorder
35 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
