Epson printer my epson printer always move to the right after i head clean & refill it.. it's producing bumping noise & turn off after a few seconds but the red light is still on. if i open it keeps moving to the right & still the bumping soundmthen moves to the left slowly.
  • 26 Answers
You need to replace your printer cartrages
Posted on Mar 08, 2008
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
Printer epson t60 the red light are always transferring to sides
you need to reset waste ink pad counter by adjustment program for epson t50 t60 printers
Mar 27, 2015 | Epson STYLUS PHOTO T60 INKJET PRINTER
Have not used my Epson R1800 for almost 6 months. When I turn on the power the printer head, with the cartridges, stayed at the very right end, not moving. The paper and ink lights flash and the head just...
Your User's Guide is available here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
After leaving the printer inactive for a extended period you should expect the ink cartridges to be dried up and the print head 'gummed' in place.
You will need to refer to page 82 of the pdf, Cleaning the Printer.
As part of cleaning remove the existing ink cartridges and while the cartridges are removed try and clean the print head of any ink residue. Note that if the red light is on or flashing above an ink cartridge the printer sees it as empty (dried up).
The print head will not move if ink cartridges need replacement; replace ink cartridges according to the red lights, likely all. Press the ink button to see if the printer will begin the charging cycle. If all is well the green power light will stay on and the red ink light will go out.
If you do not get this desired outcome try Cleaning the Print Head, page 73 of the User Guide. Hold down the ink button when the red light is off for 3 seconds. Run a nozzle check pattern; if nozzels are not printing a clean pattern, repeat this process up to 3 or 4 times.
Feb 03, 2011 | Epson Stylus Photo R1800 InkJet Printer
Printer not printing
You need to carry out a couple of print head cleans and nozzle checks. To do a print head clean you can either use the driver software (Go to printers & faxes, right click on printer and select printing preferences then the maintenance tab) or hold down the maintenance button for 3 seconds. to carry out the nozzle checks either use the software as above or turn off the printer and press & hold both buttons for about 3-4seconds when turning back on. The nozzle checks should show unbroken lines, if there are any gaps then the print head is starting to get clogged. Note head cleans use about 5 - 10 percent of an ink cartridge, if any cartridges are low they will need replacing after cleaning. Other sources of information is available from Epson on-line guide here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVGcisk9ncQeIGFU002FHBhpsVxk
Please take a moment to rate this solution, thanks.
Mar 31, 2009 | Epson Office Equipment & Supplies
Epson C64 Printer
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below).
Alternatively, if you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above!
Should you decide to have a go at cleaning or re-fixing the spring, let me know via a new posted comment so I can provide further assistance.
Nov 09, 2008 | Epson Stylus® C64 InkJet Printer
Epsom cx3200 off brand ink refill
Make sure the print head nozzles are not clogged. You may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
When you don't turn on your EPSON CX3200 for a long time, the print quality can decline. It's a good idea to turn on your EPSON CX3200 at least once a month to maintain good print quality.
1. Make sure the EPSON CX3200 is turned on but not printing, and the Error light is off.
If the Error light is flashing or on, you may need to replace an ink cartridge.
2. Press the left Menu button on the control panel several times until you see Cleaning and then press the Copy button.
Cleaning takes about 30 seconds, during which the EPSON CX3200 makes some noise and the Operate light flashes. Never turn off the EPSON CX3200 while the Operate light is flashing, unless the EPSON CX3200 hasn't moved or made noise for more than 5 minutes. setViewedFAQCookie(14082, 31605);
Oct 02, 2008 | Laser 3115cn All-In-One Printer
Epson c43sx does not print
It is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
Replace the cartridges with genuine Epson ones and try again. The genuine ink will also help to clear any hardening cheap ink in the print head.
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
change the cartridge thats simple red light indicating you must change your catridge
Problem printing
1) Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 29, 2007 | Epson STYLUS CX3900 All-In-One InkJet...
Dark red prints with lines throught the picture
1. Make sure the printer is turned on but not printing.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
41 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
