MS Access and ASP.net application
How to insert the data in the database from a .net application. i'm using c# as code behind language n getting problems while inserting text fields,number fields are getting inserted without any problem.
Please help me.
Thanks in advance.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
You probably need to be inserting the value of a text object (ie, a String) , not the object itself. In VB.NET, a String object is an actual, not unlike a Java String object. In "classic" VB, a String object isn't really handled by the interpreter as an object in the C# / Java sense, so it can be referred to directly without resolving the value via a method call. So attempting to insert an object reference into a database field from C# code will probably not work unless the database knows to call toSting() on the object, which I am 99.99999% sure it cannot (depends on the database-- in this case Access, and more particularly, what version you are using, and if there is any .NET framework interoperability).
Calling myString.toString() though returns a String object in C#, so using that is likely not going to work. What you may need to do is return a character array using the 'chars' and 'length' properties of the C# String object.
Finally, after all this, your problem could be a lot simpler: the value(s) you are trying to insert may not be right for the field-- check the length of the values being inserted, etc. Use .trim() to eliminate leading and trailing whitespace, for example. If you post your INSERT statement and an example of the data you are using, I may be able to tell you more. Also, you are in ASP.NET and data transfer from web containers to Access databases is notoriously bedeviled work.
Posted on Mar 07, 2008
  • mcc99
    mcc99 Mar 07, 2008
    P.S. Here for C#'s String() object members:
    http://msdn2.microsoft.com/en-us/library...
How to recover MDB file?
You can try to use third party Access file recovery program to recover your lost and corrupted data from .mdb files. For more details about this software:-
Access File Recovery Software
Apr 02, 2014 | Computers & Internet
How can i repair a damaged access database
There are some reasons which may damage your MS access database such as virus infection, software crash, accidental shutdown of system, unrecognized format of database, corruption of storage media etc. These issues are easy to overcome by using third party software of access database repair.you can try Kernel Access Database Recovery Software one of the best software in Data Recovery
For information you can visit here ...http://www.accessrecoverytool.net
Aug 23, 2010 | Microsoft Computers & Internet
Definition of asp.net & .net frame work
ASP.NET is a web application framework developed and marketed by Microsoft to allow programmers to build dynamic web sites, web applications and web services
The Microsoft .NET Framework is a software framework that can be installed on computers running Microsoft Windows operating systems. It includes a large library of coded solutions to common programming problems and a virtual machine that manages the execution of programs written specifically for the framework. The .NET framework supports multiple programming languages in a manner that allows language interoperability, whereby each language can utilize code written in other languages; in particular, the .NET library is available to all the programming languages that .NET encompasses. The .NET Framework is a Microsoft offering and is intended to be used by most new applications created for the Windows platform.
Jun 02, 2010 | Microsoft ASP.NET Programming with MS...
What is .net? what are the types?
.net is a platform which is used for creating standalone and web application. It is Microsoft technology and competitor of Java. .net is not a language but a framework and supports many languages. It supports around 37 languages. But mostly CSharp and vb.net is used for developing the application. Microsoft Visual Studio is used for developing .net applications.
Regards, polysandy
May 31, 2010 | Microsoft ASP.NET Programming with MS...
I want to learn that how can i connect my HTML page with my DATABASE created in MS ACCESS so that i can fill my table in HTML page directly-
1. You can use Pages option in MS Access. The page in MS Access is the web page in MS Access which allows you to access database in MS Access database.
2. You can use MS Office Front Page application and use the Form builder and connect your database in that.
3. You can also use Google Apps Business Solution for this however the database will not remain in MS Access but will remain in Docs online.
4. You can use .net application developer for this as well but needs expertise in that.
Mar 09, 2010 | Microsoft Office Standard for PC
I want ot link my inventory database to another pc
Create user account for second system in Sql
If u want to get data by code means u need to create
connection to database by using jdbc connection string .
then write a query to acces data.
create statement
pass query to that statement
run query
Statement statement=con.createstatement();
statement.executequery(querystring);
Oct 15, 2009 | Microsoft Designing ASP.NET Applications...
Connection between html and ms access
HTML page is static, means it will not interact with the database. It just shows what has been written to it.
Regarding your question, you have to use server-side scripting i.e. JSP/Servlet, ASP.NET, PHP etc.
To learn more about server-side programming see the below site.
http://en.wikipedia.org/wiki/Server_side_scripting
Sep 21, 2009 | Microsoft Office Standard for PC
What is the compatible database for visual basic 6.0?
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Mar 09, 2009 | Microsoft Press MS Access 2000 and Visual...
Asp.Net
about the dynamic forms/pages, u can use sessions in asp.net C#, theyre very easy to use and try using commands like server.transfer and respond.redirect in ur code. for the connectivity thigee u asked, :) m sorry my friend u cant get it like a pan cake, u gotta study w3schools odbc connectivity in asp.net tag for this :P
Dec 21, 2008 | Microsoft ASP NET WEB MATRIX (583797)
Creation of a dynamic web page
Okay, you can't do that with just Office 2003 professional. You'll need to install and configure the dotnet framework on your machine first, and then you could use infopath to create forms to work with, say, something like MS Sharepoint. You could use MS Frontpage to create an online form and link it with an Access database, but you will not need the dot net framework for that. It's easy and Frontpage is pretty intuitive.
Here are the basic instructions for using MS Frontpage: http://office.microsoft.com/en-us/frontpage/HP052812481033.aspx
You will also need webspace or a webhost that will support Microsoft ASP web hosting.
If you haven't done this before, it may be easier to get a professional do it for you, using either Microsoft or PHP/MySQL based technologies. It will certainly be time efficient.
Oct 18, 2008 | Microsoft Office 2003 Basic Edition...
Computers & Internet Logo
207 people viewed this question
Alun Cox
David Payne
David Payne
