Question about HP LaserJet 4600dn Color Printer
Hp color laser jet 4600dn printer on network will not print turn printer off back on will print
We have a hp 4600dn color laser jet printer at our school. It is on our network by way of tcp/ip. When you try to print to the printer the data light will not turn on. If you turn the printer off and then back on after about 2 minutes of warming up and calibrating the data light will come on and it will print.We have had the printer going on 5 years and never had this problem with it before.
  • 1 more comment
  • Jer1971 Mar 07, 2008
    When I go to the control panel and check to see if my printer is still on line it says its still online. What do I do about the buffer? What do I Do to fix my problem? So I don't have to keep turning my printer off and on all the time!
    Is it possible to reset the hp 4600 to its default settings. How would I do this? I could put the tcp/ip numbers back in if I had to.
    I have the printer on tcp/ip already. I have 3 hp 4600dn on our network in our school all on tcp/ip. The other two are still working great but the third one stopped printing unless you turn it off and turn it back on.
    Master:
  • 377 Answers
Good day!
pincer here..
Posted on Mar 09, 2008
    President:
  • 2,072 Answers
Considering you have had it for 5 years without an issue, here are some things to look for.
1. The printer software should probably be updated. Some of the printing programs have changed and your printers software may be behind, also keep in mind that the printer software itself may be corrupted itself and just need reinstalled. The printer software updates will be found on HP.com. That seems the most likely issue. What makes me believe that is turning it on and off resets and reloads the software.
2. Can you see if somewhere Internet Printing has been turned on and something is polling the machine? One way to determing if it is an issue with something being sent to the printer via the network would be to get a crossover cable and print to the machine via a laptop. If the laptop would not cause a lockup, then you have to look for what it on the network. If in particular somewhere on the network has addded internet printing, then that will cause an issue exactly like you are talking about. You can try unplugging the netrowk cable and printing the internal printer pages, but thats not as effective as using a laptop with a crossover cable and print direct.
3. You most likely have switched drivers, Although I do not suspect that as an issue, there is a small chace the driver is corrupted.
4. Bad Memory. If you have a bad Memory card in the printer, that could also be the issue. Reason why I suggest bad or a memory issue, once again is that it resets when you power on and power off. Clears the print queue and possibly restes spooling.
Since it prints once and locks up, do not waste time in IP or addressing. If it prints once you power on and off, your address is fine and not changing.
Check through your printers mennus and look for a memory reset. I am sure you have one, but before running a memory reset print out your set up, or confirmation page just to have all your set up information handy besaue you will have to reenter those numbers when you reset.
I strongly suspect software corruption of some kind.
And no you should not have to expect to turn it on and off every time.
Posted on Mar 07, 2008
  • Rick Kasper Mar 07, 2008
    Let me know if thie helps. I will look farther into it for you
    One other thought that just occured to me, Since it is calabrating and seemingly taking a long time to setup, I am beginning to wonder if you are having a cartridge issue, maybe an empty toner not being sensed properly. That is also a possibility.
  • 796 Answers
Why dont you try to update the firmware and see whether it works or not??
    Master:
  • 351 Answers
Dear JER1971 ,
Its due to heavy conjuction on your network. This problem called "Bottelneck problem" its your network related problem , you have to reduce the network traffic .
Cheerup & Be Happy always
  • Akshay Choudhary Mar 07, 2008
    Dear Jer1971,
    Then you can re-install the printer again with fresh IP address. i'm sure this will work perfectly.
    Genius:
  • 3,422 Answers
Click HERE for the user guide and go through it you will find the method to reset the printer.
Goodluck..
    Brigadier General:
  • HP Master
  • 3,614 Answers
Install A Dedicated Print Server
Sharing a printer that is connected to a single computer is easy, but it has drawbacks. The main one is that the computer to which the printer is connected must be on for anyone to be able to print, whether it's actually in use or not. If the computer is in use, performance slows if other PCs send multiple print jobs.
Additionally, if the person using the print server as a workstation has to reboot, any print jobs sent during the reboot period will go to cyber-limbo.
One way to circumvent this is by using a dedicated print server. This is essentially a workstation connected to your network with its only function being to share the printer. The downside to this method is that the server must be on all the time, or at least when you wish to print.
Another alternative is purchasing an external print server such as Hewlett-Packard's (http://www.hp.com) Jet Direct 170X External Print Server. Connect this little box to your printer via a parallel cable, then connect the JetDirect box to your network's hub.
Once connected, you can use Internet Explorer (or the included JetAdmin software) on any computer in the network to configure the print server. If you give your printer an IP (Internet Protocol) address, you can map each Windows XP machine on your network to print directly to the printer via its IP address. This means you can print to the printer from any machine as long as the JetDirect box and printer have power. You don't need to have an extra machine acting as a server.
To map a printer to an IP address, click Start and select Printers And Faxes. In the left column, click Add A Printer and click Next. Select Local Printer and click Next. Select Create A New Port. Click the drop-down menu and select Standard TCP/IP Port. Then, click Next. This starts the Add Standard TCP/IP Printer Port Wizard. Click Next, enter the IP Address you assigned the printer (the port name will fill itself in as you type), click Next, and Finish. Finally, scroll through the Printer Manufacturers And Printer Models (or click Have Disk if you have a driver disk) to select the correct driver for your printer. Click Next. Type in a name for the printer if you wish to change it (we suggest a short name, such as HP4000), and click Yes to make this printer your default printer. Click Next, select Do Not Share This Printer, and click Next again. Finally, click Yes to print a test page, click Next, and click Finish.
  • 5 more comments
  • micromaster
    micromaster Mar 07, 2008
    What answer do you want dude??
  • micromaster
    Provide all the info guy, waht OS did you use on your school..
  • micromaster
    What is Bottelneck scorpio.
  • micromaster
  • micromaster
  • micromaster
  • micromaster
    (do not delete)
    Enjoy!
    Cheers,
    President:
  • 1,944 Answers
I will have a look at the service manual and get back to you.
    Guru:
  • 1,894 Answers
HELLO DUDE
  • dewan nafees ahmed Mar 07, 2008
    i think the printer is automatically entering into offline mode....
    if your printer has no such modes then there is some problem in the buffer....
    this buffer must causing the whole problem ...
    thankyou
    goodluck
    dont forget to rate the solution
Where is the option to print black and white only (HP 4600dn)
Open the file or image you want to print.Select File>Print>Print Wizard/Tab opens>Select the printer from drop down list>Click Properties tab on the right side area>Below Color Intensity Area>click GREYSCALE PRINTING.
This work for me so give it a try.
Aug 19, 2011 | HP LaserJet 4600dn Color Printer
Respected Sir We are having HP Laser Jet Printer 4600dn it is shwoing error 82.0180 E10 2 Error? What i have to do now
You have a failed JetDirect network card (look on back where the network cable plugs in) usually a grey or white slot card with 2 thumb screws (ex: 610n). If this is add-in card, you can buy a replacement and reinstall it. If the network port is built onto the printers fomatter (main board), then you need an authorized HP repair center to replace and set the serial number through service mode.
Dec 19, 2009 | HP LaserJet 4600dn Color Printer
Our older 4600dn when a laser label is used sometimes does not fix the color for very dark or high contrast colors changes. Also following print on any paper laser or reg get a blotch of this dark color...
Sounds like you have a fuser issue. Also, there is a wire inside the unit that creates a magnetic charge on the pager that attracts the toner. If the paper is too thick, this wire is failing, or the fuser unit itself is going bad then the toner cannot be "attracted" to the paper because the magnetic charge is either too weak or altogether absent.
You could probably get the unit serviced, but the price of network printers with duplexing are quite low and may be less expensive than getting this one repaired.
Nov 19, 2009 | HP LaserJet 4600dn Color Printer
Lines down the paper HP 4600DN
This means that the problem is with the toner drum. Just try to clean the drum of the toner with cotton. It is green colored rod in the toner. then try to take the print. If still you get the line while printing please either replace the toner or get the drum replaced from a local vendor
Jul 14, 2009 | HP LaserJet 4600dn Color Printer
HP Color LaserJet 4600 Keeps Calibrating
Replace the Jet direct card in it. I had a similar problem and replaced the Jet Direct card, all was good never had that problem again.
Apr 15, 2009 | HP LaserJet 4600dn Color Printer
HP color laser 4600dn FAN noise
Yes this is normal. Everytime someone prints, the printer exits power saving mode and the fan will stay on. If you leave it on and don't print to it overnight, the fan would shut off in the mornig. But you probably turn the printer off everynight and are printing all day, so you don't really have to expectthe fan to power down unless its not being used for an long period of time idleing.
Jul 18, 2008 | HP LaserJet 4600dn Color Printer
Problem printing Pendaflex file tab labels from 4600dn
Make sure the settings are properly set within the program and printer.
Jul 01, 2008 | HP LaserJet 4600dn Color Printer
Printing error on desktop when printing to 4600dn
try re installing the original software for the printer. sometimes hp drivers get corrupted by either use or anti virus. this normally should fix the problem If it does not please come back
Apr 19, 2008 | HP LaserJet 4600dn Color Printer
I have an HP 4600dn that is having trouble printing color.
there is a setting in the menu to adjust
go to Configuration
adjust color
you have to determine which way to adjust it on a X and Y axis
try changing the number X to a high # to see which way it moves then adjust from there.
Nov 21, 2007 | HP LaserJet 4600dn Color Printer
HP Colour LaserJet 4600dn printer problem
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 29, 2007 | Office Equipment & Supplies
HP LaserJet 4600dn Color Printer Logo
312 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
