Question about Dryers
I have a Maytag Neptune MDE4000AYW electric dryer. It has been trouble free until now. The problem: When I pushed the start button, it started slow several times. I stopped using ut for 4 hours. Now, when I push start button, there is a loud humming noise, and the dryer won't turn on regardless what cycle it's on. Please advise.
  • 2 more comments
  • Anonymous Mar 19, 2008
    Hi, I press the start button on my Neptune electric dryer and it makes a loud noise like a grinding noise (almost like it's trying to start) and then thats it; It never starts. I kept pressing it and it finally stopped making the noise and I smelled a plastic type burn smell. I left it alone for about 30 minutes. It made the same noise but it started this last time after about 5 seconds of that noise/grinding/humming type noise.
  • Wendy Sanderlin
    Wendy Sanderlin Mar 19, 2008
  • tracep Apr 03, 2008
    wondering if you've found the solution?
    i had the same burning (plastic almost) smell, that gradually went away, but now a week later it will not work at all. i just unplugged the unit to check the power source, and the plug is very corroded! no wonder i smell burning, and thank goodness it hasn't started a fire! has anyone else experienced this, and what should i do?
  • Anonymous Nov 21, 2008
    grinding noise when it starts. when i go to the second load in it doesn't start wait a couple of hours and it does. Thanks Norm
    Sergeant:
  • 351 Answers
Its a motor problem check to see if theres a capacitor that starts the motor it may be burnt out it will have 16uf etc on it or the motor itself could be faulty if its covered in lint they over heat.hope this helps.
Posted on Mar 07, 2008
My maytag Neptune dryer is not working. It makes a noise when you hit the start button but doesn't start. The timer continues to go until it reaches stop. Have checked belt and it seems to be fine? Any...
I have worked at sears appliance have come across exact or similar problems. You push the button and you hear something like a loud buzzing. My experience has been that the drive motor is locked and needs replacing. Depending on the age of the dryer and the cost of a motor and installation, you might but another dryer.
Mar 03, 2015 | Maytag Neptune MDE4000 Electric Dryer
Maytag mde4000ayw won't start. moisture monitor
This is either your start switch or your motor that is bad. I would suggest you begin with the start switch. We love Maytag appliances and we also love the moisture monitor on this model of dryer.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct switch out to you asap.
We look forward to working with you and hope to get you back to drying right away.
Happy Holidays to you!
Ella
Nov 12, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune clothes dryer Model# MDE4000AYW Noisey squeeking sound. However, after a few minutes when it heats up, the sound goes away.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
trxcvhj
Jul 05, 2009 | Maytag Neptune MDE6700A Electric Dryer
Neptune Intellidry dryer.
You need to do a continuity check on the dryer cord. Also manually reset the breakers and make sure you have power (both legs). After this and you still have trouble, do a continuity test on the door switch. The door switch will keep a dryer from operating. After that, you will need to check that your motor is being called to come on. Also check the capacitor and that it is reading the correct microfarad's with in 5%.
Apr 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer model 4000, <10 y.o., hums, but won't start.
I wouldn't know about the warranty, but the dryer motor may need only a start relay, which is usually attached to the motor. Usually, this is a centrifugal device. By that I mean the contacts on the relay are normally closed to give the motor extra starting capacity when you first turn it on. The contacts open after the motor get up to full speed.
Jan 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
294 people viewed this question
Top Dryers Experts
