Back to:
Tags:
Intel D845GVSR Motherboard
Pc hangs up oftenly or show blank screen (by 2 users)
posted by sammmy1989 on Mar 07, 2008
i have an d845gvsr motherboard and my motherboard sometimes detects the ram and sometimes it doesn't. when removed ram from the slot motherboard does not even give beep sounds. but after shaking the cabinet it detects the ram and starts working but after short time it hangs up or just show a blank screen and sometime at the boot screen just hang. then after pressing restart button, motherboard again does not detects ram. i have configurd everything from bios to default settings, changed ram, changed power supply, checked hard drive for errors. i am using windows xp pro sp2.
Comment by sammmy1989, posted on Mar 07, 2008
the other slot doesnot detects the ram even if its plugged in
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Aug 01, 2008
Intel D845GLY mother board. Same problem
Best Solution
Thanks for Trying (70)
Hairy29
Rank:Wiz Wiz
Rating: 81%, 24 votes
good pm sir...
have you tried changing your mobo sir?if you already checked your hard disks and change ram & power supply i guess your mobo is the problem sir...usually if you removed your ram from your mobo it should beep for warning...try using the other slot sir maybe this will do.hope this will help...
Rating Locked! (?) sammmy1989 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on pc hangs up oftenly or show blank screen:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
pcchips m810 rev 7.1a ¨q8-overheats then gets...
Motherboards
i have msi p45 platinum MB,two graphics cards xfx 9600GT...
Motherboards
I took apart my sister's computer an XP and I'm having a...
Motherboards
hey i need help with my problem that im haveing with my...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
