Tascam CD-RW402 2-Disc CD Player / Recorder Logo
Posted on Mar 09, 2010
My recorder reads disc error on the drive side
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1324
Points
Sansui vcr dvd recorder, dvd won't play
The reading laser and the disc drive are not working for the DVD player and you will have to get the disc drive and the reading laser replaced.
I have a MJ D707 minidisc recorded discs reproduces them all well .the discs which have been recorded and deleted sometimes get error disc or disc broken, the next day he reads but records beaten to death,...
That is the most dizzying incomprehensible post I have ever seen!.
Just say what you want to say in English.
manual -- mypdfmanuals.com/user-manual,PIONEER,MJ-D707,1230701.pd
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
6helpful
Disc error cannot record
what type of dvd's are you using, camcorder can only read DVD-R, DVD-RW ( signle sided) , or DVD-R DL 9dual layer not double sided) make sure it doesn't say DVD+ needs to say DVD-
Disc Reading Error
my remote wont work recorder
Finalizing both sides
A Dual Layered (DVD-R DL) disc has two recording layers on the same side of the disc. No recording is made on the 'other' side of the disc.
Finalising the disc will finalise both layers. Most probably your computer DVD drive cannot read both layers of the DVD-R DL disc. DVD-R DL discs can only be played back on DVD devices that are compatible with dual layered discs.
Check your computer DVD drive spec to see whether it can read DL discs.
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
2helpful
2answers
Finalizing and reading discs
What a load of rubbish this camcorder is and Samsung customer service is a load of rubbish too.
10helpful
5answers
Error code 2881
I found this problem only when I tried to use a RW disk. The camera will not use a rewritable disk. I reformated the disk in my computer but it still would not work in the camera.
Top Tascam Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
