Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Just bought a PANASONIC PT-47WX53G On ebay for what I thought was a steal. It was explained that somehow someone got into the service menu and messed something up with the convergence on the green gun. Apparently the picture at this point is unviewable. mentioned that a service tech looked at the set and said that it was probably a $10. part called the e-prom? first of all I need desperately to get this set working properly. the screen is completely distorted. Is that sounding like something more. Please help me with this. I printed out some other info on resetting the tv to factory defaults, and some iffy info on the convergence itself, I just kinda find it hard to believe that a tv can be so messed up just by pressing some buttons that obviously should not have. I'm new at this stuff on projection tv's but am pretty handy with alot of other stuff electronic. can anyone help, or am I seeing this for more than it is?
  • Anonymous Apr 01, 2008
    having the same problem . but my set has red green and blue lines in a round pattern on the bottom of the set . it looks like a sun rise . when the sun is half way up ? under warrenty. any good techs in colorado springs colorado.
  • 8,596 Answers
You can try restoring to factory defaults, and you can try the manual convergence option. If the manual convergence fails to reset (as in, the crosshairs physically will not move), then the convergence board is bad, and will need to be replaced or repaired (if you are a good circuit solderer).
Posted on Mar 07, 2008
How to replace the lamp for Panasonic projector
If you bought a lamp from eBay then its most likely not a real brand bulb. The PT-AE1000 uses an ET-LAE1000 lamp that should have an Osram, Philips or Matsushita brand bulb. If you do not see PVIP, M or UHP on the bulb then its most likely your problem. Cheap lamps are not worth the money. They fail early and end up costing you more money in the long run. Panasonic Projector Lamp
These folks sell lamps that always work. I would return the eBay lamp and buy one that will work. Their support and customer service are one of the best in the industry.
Aug 11, 2015 | Panasonic PT-AE1000E Projector Lamp...
Pt-47wx53g tv won't click over n than the power button will blink 5 times
IC4511 has failed on the DG board replaing the DG board as a unit i the only way to fix the issue. The DG board isnt serviceable
Jun 01, 2012 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
PT-47WX53G. TV got moved. Unable to move blue
The convergence ICs have failed which is very common when the set has been moved as a wek IC wont allow the color to be moved. You can get the PT52WX53G convergence repair kit from www.tvrepairworld.com which is the correct one for your model. The kit contains the parts and the CD with repair instructions.
Apr 10, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt-47wx53g picture looks like it is 3D. What do I need to do.
Install the PT53WX53 convergence repair kit available from www.tvrepairworld.com the kit contains the ICs, Resistors and the CD with repair instructions.
Jan 21, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hi, We need solution for B-Ray connection to PT-47WX53G
We solved the problem with Sony experts from Vio. Thank you
Jan 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WX53 does not turn on
Yes, I did try to use the power button on the TV itself. That did not work too. Yes, there is blinking red light too. I searched through several sights and found out that it is an issue with the IC 4511. I could not find a place to buy the chip.
By the way, our local TV dealer asked for $400 to fix this issue. I had already spent $400 on a different repair on this TV, 6 months ago.
Any suggestion/advice would be very helpful. Thank you again for your response.
Feb 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
231 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
