Can a washing machine travel on its side. I want to pick one up and take it home in my car will i be able to do this
    Sergeant:
  • 351 Answers
If its a front loader you may damage the suspension or break somthing else inside,you can fit transit bolts to them.if its a top loader you can lay it down just take care.but it is better to stand all machines upright if possible.
Posted on Mar 07, 2008
Get a lot of vibration on the high spin cycle. Looks like I need to replace the bearings. Can you replace just the bearings? I saw the whole drum can be replaced.
It depends on the make and model of the machine you have. Some drums are bolted together with a front and a back half that split apart. some are heat sealed at the point of manufacture and can't be split. If you take the top off your machine, it should be pretty cleat if the 2 halves are bolted together (You will see bolts). Just be aware that for the noviice, this is a nightmare job. Not only do you have to get the drum out, you then have to knock out the old bearings with ppopriatly sized drifts, without damaging the seats they sit in. THEN you have to get the new ones in without doing any damage to the bearings ot the seats, then you have to get the seal between the 2 halves to seal without any leaks. I recondition machines for a living and I avoid bearing swaps like the plague. I would seriously consider consigning the machine to the scrapheap, rather than doing it yourself!
Sep 25, 2015 | Washing Machines
Lint catcher doesn't...
the fan is blocked up with lint so isnt providing enought travel of air
you need to strip open the fan and clean the blades
Oct 21, 2014 | Simpson Washing Machines
Bosch Coffee Maker
http://portal.bsh-partner.com/portal(bD1lbiZjPTA2MA==)/PORTALFRAME.HTM
Enter model number.
if that is a perishable link, start from http://www.bosch.com pick "continent" then pick your country then "home appliances" then "support"
Jan 29, 2012 | Bosch Washing Machines
Where are the travelling bolts found in the front loaders
They will be in the rear of the chassis one either side, about an inch from the side and almost exactly half way up. Typically they will have a 10mm head and be set in a plastic cup
Jul 27, 2011 | Whirlpool Washing Machines
My daughter in law's machine won't pick up the bobbin thread. I've never even seen a bobbin that loads like that so I don't know what to tell her. In fact, I've never even heard of a new home sewing...
New Home is Janome.
The bobbin thread may not be picking up because the needle is in backwards.
Refer to the manual for the machine - some require the flat side of the needle face to the back of the machine and some to the left side of the machine.
May 07, 2010 | New Home L-373 Mechanical Sewing Machine
Need the instructions
I found this Link at Siemens Home page in the UK. I don't know if that is where you are but they also have several other locations to pick from. Also a similar model might give you the guidance you are looking for
http://www.siemens-home.co.uk/our-products/laundry/washing-machines/WM14S79BUK.html?source=browse
Nov 30, 2009 | Siemens WXLS142GB Front Load Washer
Engine started dying after serpentine belt replaced. Had mechanic check codes, none showed up. After picking up the car, drove 5 miles, engine died again frequently on way back to machanic. He drove and...
If I remember correctly, the serpentine belt change on this motor can be quite involved. It may require the battery being disconnected to avoid shorting out cables. Check for loose battery cables especially on the negative side where it is secured to the engine block.
Jun 20, 2009 | 1998 Pontiac Bonneville
I need to change the plug on my washing machine.
If you have never before - it's best to hire a professional to avoid problems/fires/etc.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Kenmore Washing Machines
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
