Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Samsung washing machine WA71N2
Sir,
i have samsung washing machine since 2 yrs. all of sudden it stopped draining water and doesn't spin. when its empty it spins.
pls help
thanks
  • Anonymous Mar 24, 2014
    I wasn't home when the pump went bad but my wife found water leaking and turned everything off. I found the water pump had busted out of its' plastic mounting bracket and the hoses and wire had become disconnected. I got a new pump assembly and installed it. I leveled the machine and put water in it. I then put it on Spin only and the pump worked fine. The only problem it wouldn't stop running. I turned the power button off and it did stop. However as soon as I turned the power button back on the pump immediately started again. I turned the power off and unplugged the machine. When I plugged the machine back in the pump would start running immediately, even before the power was turned on. If I turned the power on the pump will keep running. If I then turned the power off the pump will stop. But as soon as I turn the power on the pump starts again. Any ideas?
    Sergeant:
  • 351 Answers
Can you hear the pump making any noises,if you can (humming sound)then it may be blocked with lint,coins etc.if the pump isnt making any noises then it may be faulty or a broken wire to the pump or you have a no drain button pressed in . hope this helps
Posted on Mar 07, 2008
Washing machine wont drain
Does the washer spin when in spin cycle ? If it does spin and there is no water coming out of the drain then you most likely have a bad wa
Aug 07, 2012 | GE Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Water doesn't drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 08, 2011 | Whirlpool Washing Machines
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
heatman101
Jun 25, 2011 | Washing Machines
GE model wwse5240G washer suddenly stopped working full of water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 19, 2011 | GE WWSE5240G
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
heatman101
Dec 12, 2010 | Washing Machines
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Washer not spinning
check the sensor switch located underneath the the top washer where the door closes , make sure contacts are clean (or align for magnetic SWITCH)
May 05, 2008 | Kenmore 3.5 cu. ft. Front Load Electric...
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
277 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
