My maytag washer is leaking under the outer tub
  • Andrew Ullom Mar 07, 2008
    the model is pav2300aww. its leakin above the transmission. thought it may be the tub assembly. what do you think?
    Sergeant:
  • 351 Answers
Dont know what model you have but it sounds like the boot seal is leaking if its near the shaft(top loader).does this help or can you tell me model
Posted on Mar 07, 2008
  • Ian Greenland Mar 08, 2008
    it may be a crack in the outer plastic tank,because the outer bowl just screws to the top of the gearbox and thers a seal there.i havent had to replace the seal, but there have been alot of problems with this model.
My Maytag A9700 is leaking from the bottom of the outer tub. I have changed both the tub bearing and the stem seal but it is still leaking - even more than before I started. My question is whether I
If the boot seal was properly seated onto the outer tub lip, then you should focus on the water seal (#39 in the graphic - it should have come with the mounting stem kit) as the source of the leak. Extra care must be used when installing this over the agitator drive shaft - some recommend adding a lubricant (Maytag center seal grease works well) to the shaft before sliding the mounting stem (and water seal) down onto the agitator shaft. Also, check the two sealing surfaces where the top of the boot seal (#40) meets the bottom of the mounting stem (#30). Look for cracks, chips or any bits of debris. Anything that keeps those two surfaces from meeting perfectly will cause a leak. These repairs should go fairly smoothly, but leaking water seals and chipped boot seals can cause problems.
Dec 06, 2014 | Maytag Washing Machines
Leaking at bottom of washer after it spins out not alot of water but a pain in the ****, how do you get in to the back of the washer?
The FAV6800A and FAV9800A only have access thru the front panel and washer top once released fromt the base......no rear or side access. See Pick of Outer Tub removed for Tub Seal and bearing replacement.
Google ""16022808.pdf"" to find the Service Manual.
Page 33 will show ou how to release the top cover and page 41 for front cover removal.
If you have wash water leaking down on the Clutch Pulley I feel you have a Tub Seal leak. The issues could be related to the drain hose/drain pump or cracked outer tub.
I don't troubleshoot on this forum to difficult to carry on thread. Google ""Neptune TL Washer FAV6800AWW"" or ""FAV6800A/FAV9800A Outer Tub bearing replacement"". Two DIY forums I frequent that I feel are true DIY forums.
Sep 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Leaks when it is spin mode
Unplug the 120VAC washer power cord. Then pull the front cover off the machine ad see if you can ID the leak.
I'm seeing that around the 5 to 6 yr mark it's time for a Tub Seal replacement and possible Outer Tub and Spinner Support bearings should be replaced. It's not too bad for most DIY owners.
Google ""FAV6800A/FAV9800A Outer Tub bearing replacement""
I post under dh1200s on that forum and this one also. If you are slightly handy you can do all repairs on the FAV6800A and FAV9800A. I can also point you to the Service Manual for the machine.
If you are going to DIY I would to the forum that you find the above post........D*ick
Feb 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have water coming out from under the washer. What should I look for?
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only During drain and spin only All the time During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make
Jan 02, 2010 | Maytag PAV2300 Top Load Washer
Leaking, but no service person seems to be able to determine from where the leak is coming. It is a Maytag. Purchased in 1991
During fill only
All the time
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 07, 2009 | Maytag Washing Machines
Maytag Neptune leaks several hrs. AFTER I finish using it.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
if that is checked then ---------------
During fill only
All the time
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Oct 22, 2008 | Maytag Atlantis MAV7260B Top Load Washer
THE WASHING MACHINE IS LEAKING A OIL LIKE FLUID UNDER THE MACHINE?
During fill only
All the time
During fill only
All the time
Jul 18, 2008 | Maytag Performa LAT2500A
Maytag washer door boot
During fill only
All the time
During fill only
All the time
Apr 02, 2008 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
