My Ge wssh300gww will
My Ge wssh300gww will not spin. Once the cycle reaches spin all the green lights flash and it beeps. the water will not drain and the spin cycle will not engage. What can I do?
MY MACHINE JUST SHOW THE LED LIGHTS BUT IS NOT STARTING THE CYCLES.YOU CANNOT HEAR THE CYCLE WHEN SUPOSSED TO START GETTING THE WATER TO WASH.
  • 2 more comments
  • CHOCOLETO Mar 07, 2008
    I REALLY NEED HELP THANKS SO MUCH
  • Anonymous Aug 06, 2008
    My GE WSSH300GWW has a problem once it goes through the wash cycle it attempts to pump the water out but nothing happens. It makes a noise like it wants to pump but nothing comes through the drain hose. I checked the hose and it is clear. How do I check the pump? Is there a diagnostics test I can run. This machine is just over 1 year old and slightly out of service. Help....
  • mjmeeu Apr 14, 2009
    My GE wash machine M# WSSH300GWW will not spin out althought it will pump out the water, I cleaned the pump stainer which was pretty much plugged butdidn't help. The drum turns back and forth but never goes into full spin cycle.
  • Anonymous Mar 16, 2014
    no spin
It is probably a clogged pump (don't look in owners manual for info - curiously it isn't in there - just says call tech - bolocks!)
Remove 2 screw on front bottom panel.
Remove cover.
Plastic boot and pump are on right had side. Clean out - and use the change to buy a drink - celebrating the fact you didn't have to spend hundreds on a tech!
Posted on Aug 25, 2008
  • melissahays Aug 25, 2008
    remove front cover (screws on bottom front).
    clean out rubber boot and pump.
    probably just clogged.
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Mar 07, 2008
  • Trey Christensen
    Trey Christensen Jul 01, 2016
    Thanks for the advice. Not only did I find change, but also a missing credit card.
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Fisher & Paykel Pride 5.5 won't wash. It fills with water then starts to beep. I can advance it to the rinse stage so it drains the water, once the water is drained, it starts to beep again. The...
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
Jul 12, 2011 | Washing Machines
GE front load waher Model #: WSSH300GWW fills and agitates, but does not spin and drain.
take drain hose and lay it in a bucket to drain water or a wet vac works better. remove 2 scews from lower pannel it will drop down and come off. look for a accordian shaped black hose. disconnect it and remove junk in it. check inside the pump inlet for stuff it's the thing one end of the funny hose is hooked to. put back together and don't over tighten clamps nut driver tight is fine.
Feb 17, 2010 | GE Washing Machines
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
As the other posters mentioned, the problem with draining is most likely caused by a clogged filter. Mine had 14 cents, 2 zip ties, and a bra wire stuck in it. Here is the process (after many hours of swearing and bleeding) so that it should be pretty easy.
The first step is to tilt the washer back so the front is 3-5 inches off the ground. Prop it up with something. To remove the front lower panel, there is 2 phillips screws under the bottom edge. Remove the screws and the panel should drop down off the pegs holding the top edge in.
Inside, attached to the drum you will see a rubber boot with an accordion sleeve which contains the filter. There is 2 green spring hose clamps (the source of many expletives) and a silver phillips screw on hose clamp. To get at the filter, you should not need to, nor do you want to, remove the green spring clamps. You will spend hours trying to get them back on.
I have attached a picture for reference. Unscrew the silver clamp (large one, closest to drum) and pull down the sleeve to get access to the filter. If you are full of water, you can slide a pan inside the machine and just pull down the edge closest to the pan to drain until the water is gone. Reach down into the accordion (gross) and grab the filter. It has a lip on it so you will need to work it out through the accordion thing, but it likely has some really gross stuff in it. Clean it out, wad it back into the boot, and reattach to the drum. Dump about 2 gallons of water into your drum to make sure you are not leaking. Switch the knob to spin cycle and hit start 2 times. It should drain the water out within a couple seconds.
Feb 17, 2008 | Washing Machines
Washing Machines Logo
985 people viewed this question
Top Washing Machines Experts
