Question about RCA F32649 32" TV
Television only locates 7 channels????!!!!!
When i bought this tv 5 years ago i connected it to cable satellite...i never allowed the tv to search for channels locally...now that i gave my tv to my grandmother and i connect it to an antenna it only locates 7 channels...and the channels that she mostly watches are not picked up by the tv and these are local tv channels that other tv's pick up easily...i tried many times to do channel searches and it only finds 7...is there another way to add or to program regular tv channels??? thank you!
    Scholar:
  • 135 Answers
Hi there!
If you cannot receive all channels it may be a fault with the antenna or the tuner may be faulty. If you have a VCR, you can tune that into the TV first and then tune the VCR to see if you then receive all channels. If so, use the VCR position on the TV to view and select or change channels on the VCR only. Good Luck,JUS004
Posted on Mar 09, 2008
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Connecting JVC television set model AV29LX2 / JVC home theatre system/satellite decoder / Sony DVD recorder
You need to buy a splitter in order to put one to the DVD recorder and one to the tv from the decoder. You should be able to get one at the Local Radio Shack or other electronics store.
If you need help locating a store, please let me know
Otherwise Thank you for using Fixya and Have a Good Day!
and Good Luck...
Apr 19, 2008 | Televison & Video
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Apr 07, 2014 | AOC Televison & Video
What channel does it need to be on to recieve satellite tv
If you have a modern (made in the last 5 years or so) cable or satellite box connected to a flat panel TV the connection is probably coming across a component, composite, or HDMI connection. In any of those cases the TV would get the signal from the satellite box on one of its video input sources not on a "channel" that the TV tuner would select. That used to be the case years ago with VHS, but not anymore. You could also check your satellite provider's website or the TV manufacturers website for a "quick setup" guide that could help you out.
Mar 05, 2011 | Televison & Video
No signal onthe screen
If you are connected to a high definition cable box or satellite tv box you would not need to turn to channel 3 on your television. The television would need to be in the right input either component or hdmi. If someone connected the tv to the cable box or satellite tv box with a coax cable like an antenna cable then the tv channels will be available on channel 3 as well but they will not display in high definition. You change channels with the cable box/satellite tv box remote control. If the above is not correct and you are only connected to an antenna cable and not to a cable box or satellite tv box you will need to complete a channel search from the tv menu. It sounds like you are using a cable box/satellite tv box and that the tv is on the wrong input. If the cable box/satellite tv box is not working (i.e. just a black screen) on your television than that is a different matter entirely.
May 10, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Programming Channels
Your TV is likely set for "AIR" tuning rather than "CABLE" mode. In this case channels above 13 don't tune correctly. The tuning mode is adjusted through the setup menu (it's been too long since I've seen one of these to remember exactly how the menu looks). Once you set the tuning mode for cable, all the available channels should come in properly.
But you've said you have satellite, so you should have a satellite receiver connected to your TV, and you'd be changing channels there rather than on the TV. Your TV would be staying on channel 3 or 4 (if using the satellite antenna output connection), or on the A/V input you have the satellite connected to (if using the direct A/V outputs). Am I missing something about your system?
Feb 18, 2009 | Mitsubishi WS-73905 73" Rear Projection...
Local channels gone?
You need to go to set up menu & select the cable & start
Feb 01, 2009 | Televison & Video
RCA Colortrak 2000 remote control will do everything except change channels.  I have Insight coax cable, just having disconnected from Direct TV satellite connection--only because new apartment does not...
I called RCA's 800 number on the back of the owner manual--got a response that said to replace the unit since only the up-down channel changer buttons were not working. Using another remote (universal) now--cost only $5.
Dec 13, 2008 | Akai LCT2701AD Television
Initial set up w/directv
First, I hope you got an extended warranty with that. Otherwise it's a disposable T.V. after your warranty is up.NO PARTS are available. Hope it lasts more than a year..if your lucky. You need to change the channels on the direct tv box. Don't scan the t.v. You need the t.v. on channel 3 or video input that the box is connected to. Do you have hdmi cables? How did you hook the box to the T.V.? Did you read your book that came with the T.V. about hooking it up with a cable box??? Same thing as Direct T.V. box. That should show exactly how to connect. More info will help dtermind your problem.
Dec 05, 2008 | Dynex DX-LCD37 TV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
RCA F32649 32" TV Logo
211 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
