Hi, there is software to do this but usually you have to buy it. I already have the software. If you wish you can email me the file, (if its not too big) and I can retrieve the password for you and return it to you. Let me know if I can be of further assistance.
Regards
SeaJade
itsme77@bigpond.com
My opening screen is linked to main table in db. I have set each field to locked so users won't edit...
(More)
My opening screen is linked to main table in db. I have set each field to locked so users won't edit in error. I added an "Add, Delete or Edit" button to open an almost identical screen that can be edited. Both are bound to the same table. When the second form opens, no records show up, but the user can add a new record. I want it fully populated so the form can be used to edit existing records. I assumed that the problem was the other open form, so I added a macro that first closes the original form, then opens the editable version. Still no records. I can open it directly from the list of forms and it populates correctly. Data Entry is set to No and Recordset type is set to Dynaset. How to fix? Thanks
i have a problem with ms access 2003. I want to my some form fix with window or maximized. but when...
(More)
i have a problem with ms access 2003. I want to my some form fix with window or maximized. but when i close another form the maximized form is Resized.
I have a database built. In the Form I enter a Center and in a seperate box the County it is in....
(More)
I have a database built. In the Form I enter a Center and in a seperate box the County it is in. When I send out my surveys each Center is assigned a number that is only for that Center. I want to speed up my data entry, so I'm wondering if there is a way to simply enter my assigned numbers so that when it is entered, it will come up as the specific County and Center for all of my reports. Can this be done with a query or a Macro? I figure I would have to build a spreadsheet for the program to reference but I don't know where to go from there.
