My washer Whirlpool compact made two "puff"s and died in a midle of a wash. The repair man try changing all the parts (computer parts) on the top of the washer with no succes. It's being a month and the problem has not been found. Thank you.
  • grahel Apr 03, 2008
    The Whirlpool technician did find the problem after a few hours work. The latch door control on that model is defective and needs to be replaced. It court-circuit the door’s control and one of the wire inside the machine.
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Mar 07, 2008
Problem with washing machine spin cycle.
see if belt is loose if it is a no belt model you will need a repair man to change some parts
Mar 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Completely dead
Call manufacturer,they do have warranties that repairmen don't tell you about.
Apr 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
OASIS KENMORE WASHER
Before you junk the machine try calling and complaining a ton to kenmore. It is a faulty part no matter what they tell you. They have completely remanufactured it to make the board better. so they know this is a problem. If you can get them to pay for part of it... its a great washer!!!!
Nov 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washer Problem
cabiros dont have a wig wag switch check your drain pump for obstructions to find the right repairman go to www.whirlpool.com under support enter your zip code under find a service tech and they will give you a list of people in your area
Jul 07, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
