Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Cabinet removal I need to move my tv, but it won't turn the corner on my basement stairs. Is there a way to remove the cabinet base, or separate the tv into a couple smaller, more manageable parts?
  • 492 Answers
Unfortunatly no there isnt. The tv bottom contains all the circuits, color guns, speakers. From where the bottom of the screen starts to the top is all part of the entire cabinet which is molded plastic. The top part contains a mirror and the screen you see as well as possibly a remote sensor. Short of sawing it in half and tossing it away you could take it apart but this would have to be done completely to gain you the most space and could be dangerous considering the high voltage transformer that the unit uses to power the color guns.
Posted on Mar 07, 2008
I am trying to get my 65" Mitshubisbhi TV to
Normally there are two screws on each SIDE of the cabinet and are covered with a removable cap.Remove caps and plugs and cabinet should separate at side split lines.
Oct 15, 2011 | Televison & Video
I bought a used kp 61hs30 sony projection tv. It is too tall to fit down the stairs into the basement. I heard the top part with the screen justs lifts off the base - where the components are (after you...
The top as you describe it, can be removed for cleaning and moving. There are no electronics there and allignment will not be affected.
Hope this helps.
Dec 29, 2010 | Televison & Video
Hi I want to move the TV to my basement. I
ON THE SIDES THERE ARE 4 SCREWS THE TOP LIFTS OFF
Dec 15, 2009 | Mitsubishi WS-65908 TV
Old (!) freezer needs to be cut up to be removed from basement
you need to call someone (hvac company) to recollect it legally. they'll need to install a pierce valve and **** it out to collect it. it's illegal to let it out yourself. 1800 junk might do it for a small fee.
Aug 05, 2009 | Hussmann Freezer Gelato Pan Rack (For 18...
Can I remove the base to this TV to move it?
Yes the set can be disassembled and then reassembled. But you would need the service manual that will explain how to get the set apart into seperate pieces. Heres a link to where you can get the service manual for your model they send it by download link.
http://servicemanuals.vstore.ca/product_info.php/pName/av65wp74/cName/jvc
Jun 15, 2009 | JVC AV-65WP74 Rear Projection Television
Old freezer in basement
eihter your renting an appliance handtruck ( has stair climbing ablities), or your cutting up in peices and carrying out
Jan 31, 2009 | Freezers
Moved, now can't get the TV downstairs
it went down the stairs in one piece it should come up the same way
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Moving the TV
you should be fine as long as you don't drop it of course. you and turn and twist it any which way but id say measure the height of the tv because at some point you will have the top and bottom of the tv touching 2 different walls if im not mistaken
Feb 13, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Disassemble Rear Projection TV
well the short answer is : Check the sides of the set see if there is a crack in the middle where you could separate them
Long answer: i would not recommend it even if it does, the screens are sensitive and could get dust inside the screen.
Never taken one apart that far. i suspect most tech don't because of the problems aligning and dust ect.. trying to get it back together.
Dec 13, 2007 | Philips 60PP9202 60" Rear Projection...
Relocating tv
Yes, this set does come apart for moving. Remove the lower screw from each side of the TV back. On both sides, pull off the two plastic caps and remove the two exposed screw. Lift the cabinet top straight up until the guide pins clear the holes in the bottom cabinet. Be careful and don't drop anything.
May 03, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
180 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
