Question about Zenith B32A24Z 32" TV
TV has multiple images and flickers, images are not centered and different sizes? What is wrong?
Subject: Zenith B31A24Z 32'' TV
So it was made in 2000 and has been fine for the most part. Currently when you turn it on, the image will be flickering three overlapping images. Then it will "warm" up and start acting normal. But change it to another channel and it does that flicker thing again. It's now to the point will it will never go normal or rarely does,
Does anyone know how to fix this or know what the problem could be/cost?
much thanx!
  • YourHalo Mar 17, 2008
    I don't feel this is the problem as it also happens w/ the DVD player plugged into the line in. My discription may be off.
    It has a rolling screen, which flickers causing what looks like to me like overlapping images. Before when you turned it on it would start off like this then "warm up" and act normal. However, the normal stage hasn't been lasting long. Now it doesn't ever act normal. Just this rolling screen, on every channel and the line in channels.
  • 492 Answers
Multiple image is usually a result of transmission problem. The signal from your local station gets transmitted two ways, by tower and cable. If the tv receives them both at seperate times it will create an overlap or shadow effect. I would try a small power booster on it, if not a service man may have to adjust the internal circuits.
Posted on Mar 07, 2008
Where can I find the value of a Zenith TV B32A24Z
Contact the authorized service center for Zenith
Aug 31, 2012 | Zenith B32A24Z 32" TV
Ghost image in screen
Check the part labelled A63AGD00X, last numbers and letters may be
different. 99% of Zeniths 25" and 27" size tv sets had the same part from 93 through 96 bad by the time they hit 4 or more years old.
Jul 03, 2010 | Zenith SY2551S TV
Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
Feb 02, 2010 | Zenith A32B84R 32" TV
Zenith 32" TV Chirping Noise No Picture
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Jun 09, 2009 | Zenith IQB32B42W 32" TV
PLTV-32- Picture on screen is larger than TV screen.
if you have HD cable try shrinking the picture there. LCD's are not subject to 'bloom' like
analog tvs. try the aspect button on the remote.
wrong picture size on a digital tv is a result of the input signal.
Apr 05, 2009 | Protron PLTV-32 Television
Panasonic Plasma with flickering image.
how to installation oracle 9i in fedora 8
can u tell me step by step
my email addres praveen_jujare@yahoo.co.in
Feb 10, 2009 | Panasonic TX-32PK2 32" TV
What is the rate of continuous frame advance?
The continuous advance speed is approximately 2 fps (frame per second), but actual speed may vary depending on the subject or according to the selected image size. The maximum number of images that the camera can capture continuously is as below. Fine: 5/8/11/23 Std: 7/11/16/32 Econ: 11/17/22/40 Super Fine, RAW: Not available (Image size: 2560x1920 / 1600x1200 / 1280x960 / 640x480) On the other hand, the UHS (Ultra High Speed) achieves up to 7fps continuous capturing. The maximum number of images that the camera can capture continuously is as below. Fine: 15 Std: 31 Econ: 39 - Image Size is 1280x960 (SXGA) only. - AF, AE and White Balance are locked for the first frame in the series. - 1/8s or faster shutter speed is automatically selected. - Digital subject program is unavailable.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
E-mail images
What is the Macro function used for? The Macro function allows you to take close-up pictures. Use the Macro mode when you are 8.4” to 19.2” away from your subject. Where is the Reference Manual for the D-390? The Reference Manual is located on the Camedia Master CD-ROM and is available in four languages (English, French, Spanish, and German. The manual can be viewed on your computer screen or printed on your printer. How can I get traditional photo prints from my digital camera? Most photo processing centers or digital printing Kiosks can make traditional photo prints from a digital camera. There are also many on-line photo processors which conveniently deliver prints by mail. You can also make prints yourself if you have a photo quality printer like the Olympus P-400 printer. Why are there so many quality settings? Different quality settings are used for different purposes; for example, lower quality settings can be used to e-mail pictures because of its small file size. Higher quality settings are used for printing photo quality images. What settings should I use to get the best picture quality? The best picture quality setting on the D-390 is SHQ (Super High Quality). The SHQ file is the largest of all four quality settings. The image file size is approximately 786K. What is the video output used for? The video output is used for viewing images from your camera to a TV. A slideshow can be accomplished by using the camera hooked to the TV or recorded from a VCR. When taking macro images, can I use the viewfinder? Since the viewfinder sees the subject different than the picture taking lens, we recommend using the LCD monitor screen for taking macro pictures. The image previewed on the LCD monitor will be the exact image that is taken. How do I make a Panorama picture? You can easily make panorama pictures with your D-390 by “stitching” together multiple pictures. First, activate the panorama mode on the camera by selecting Mode Menu - Camera - Panorama. Take your pictures while making sure to overlap the edges of the images. Download your pictures to a computer and then use the “Panorama” function in Camedia Master to stitch them together. For more detailed information, please refer to the camera documentation. What is movie mode function? The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode. Can I add sound to a movie made with my D-390? The D-390 does not record sound in the movie mode. What is the best way to e-mail images? E-mailing pictures that were taken with your camera is as easy as attaching a file to your message.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
If there any way to get a properly aligned image when recording a document or some other rectangular subject that is not straight?
When the camera is at an angle to a business card, document, whiteboard, or other rectangular subject, one side of the subject in the recorded image may appear longer than the side opposite from it. This is called "keystoning," which is caused by the difference in distance from the camera lens to each side of the subject. The side of the subject that is closer to the camera looks longer and the side further from the camera looks shorter. Using the camera's Business Shot Mode automatically eliminates keystoning and gives a normal shape to rectangular subjects. Though the Business Shot Mode is able to eliminate the effects of moderate keystoning, certain conditions may make automatic keystone correction impossible. Also note that the maximum Business Shot Mode image size is 1600 x 1200 pixels. If you have the camera configured to record larger size images, recording with the Business Shot Mode will produce a 1600 x 1200 size image. When the camera is configured to record images smaller than 1600 x 1200 pixels, the Business Shot Mode will produce images in accordance with the currently specified image size.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Zenith B32A24Z 32" TV Logo
222 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
