Question about Canon PIXMA MP160 All-In-One InkJet Printer
How to fix this?
My canon pixima mp120, when i turn on my printer, there's a sign appearing first E then 2 and then 7 what does it mean? after that on my monitor theres a msg apearring and it tells that the ink absorber is almost full.... what it does mean and how can i fix it?
My printer is saying I have a paper jam and there is not one
Posted on Jan 29, 2009
The ribbon behind the ink is off and it will not print
Posted on Jul 14, 2008
  • 13 Answers
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2.When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3.
When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4.When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
Posted on Mar 11, 2008
How to fix 27 error
"Just this morning while I was about to print some documents, I encounter a E27 error on my Canon Pixima MP145 all-in-one printer. This type of error occurs when your waste ink absorber is full. The first thing I did was I clean the holder and the cartridge itself, remove excess inks, spills and some dirt but still no luck. The last solution that I did was I reset the waste ink counter which is not easy and requires lots of trials and tons of patience because it took me I think 10 times before my printer finally resets.
1. Turn off your printer then press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button twice while pressing and holding the Power button.
3. When you release the Power button and the Stop/ Reset button, your printer will move into a service mode.
4. When the on/off lights is in green, press the Stop/Reset button 4 times. You will then notice that each time the Stop/Reset button is pressed, the LED lights alternately in orange and green.
5. Turn off your printer.
6. Turn on your printer.
7. If unsuccessful go back to first step and try again icon biggrin How to Fix Error 27 on Canon Pixima MP145 ."
thanks
bhupi....
Apr 19, 2011 | Office Equipment & Supplies
Driver canon pixima ip 100
1st You download Printer Driver. Canon PIXMA Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 05, 2010 | Canon PIXMA iP100v + lithium battery...
My canon mp120 continually flashes an E and won't seem to print, scan or copy.
Try uninstalling the drivers. (You should be able to do this from Add/Remove in Control Panel.)
Disconnect the printer.
Re-install the drivers.
Dec 26, 2009 | Canon Office Equipment & Supplies
MP120 producing black dots on page when printing
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-11
Apr 23, 2009 | Canon PIXMA MP160 All-In-One InkJet...
No installation disk
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Mar 21, 2009 | Office Equipment & Supplies
Codes printer canon mp 160
Go to www.usa.canon.com/consumer/controller?act=SupportIndexAct
#1 Select Multifunction
#2 Select Inkjet
#3 Select Pixima MP 160
GO
Scroll down to Please enter your question bar
Click mouse inside the bar area
Type in code
Click on search
Jul 30, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixima Ip3500 won't recognize new magenta cartridge
Paste the address below into your browser window.You should find some help there
Jul 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
How to fix it
the ink absorber MUST be emptied on a regular basis. check this link(for drivers) and follow the Canon links to support and then user manual.
Mar 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Vista laptop and canon pixima mp610 printer
Go to the site listed below and download the drivers for vista, on that page you will have to use the pulldown menu and choose your operating system and it will show you a program that is updated for vista. Use that program to install the printer on your laptop.
Hope this helps
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15604
Jan 23, 2008 | Microsoft Windows Vista Ultimate Edition
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
289 people viewed this question
old marine
old marine
