Question about Roper REX3614KW Electric Dryer
My Roper Electric Dryer will not heat
I have a 29in. Roper electric dryer which is about 2 years old which will not heat
  • 1 more comment
  • Anonymous Jul 13, 2008
    dryer blowing, but not heating
  • ram41964 Sep 07, 2008
    Hello!
    I have a Roper Dryer (mod. # REX3614PWO) that doesn't dry. I run the
    machine holding the door switch in, and the following happens: Heating
    Element comes on for ~ 30 - 40 seconds, shuts down for ~ 1.5 minutes.
    Heating Element comes back on, only for about 20 seconds this time, and
    shuts down for at least 2 minutes, and the pattern continues... less
    time for the heating element and more time for the intervals between.
    Is this a thermostat issue?? Is that hard to deal with? HELP!
    Thank You!
    Rich M.
    (p.s. I've already checked my ductwork... it's fine)
  • john gagnon
    john gagnon May 11, 2010
    Hi the dryer will not run properly with the door open It will cut out just like you are saying , close the door and try Let me know what happens
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
Roper Electric Dryer...model RED4440XQ0 will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Roper RES7646KQ Electric Dryer
My roper dryer is not giving off any heat. and everything else works just fine. The dryer is only 6 years old. I also just cleaned out the lint trap straight through.
You did not say if your dryer is gas or electric. So if your dryer is electric go check out this electric no heat tip...
and if you dryer is gas check out this gas no heat tip....
heatman101
Aug 27, 2010 | Roper Dryers
My dryer is about 7 years old...it runs but no heat isnt spewing out....and it only works on the "timed" settings......Its a Roper super capacity.....model number RGX5634KQ2....serial...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Whirlpool Dryers
Dryer (Roper, electric) won't heat
Its probaly gone open circuit, however there is a thermistor that prevents it shorting out, you need to locate it and test it with an ammeter
Mar 25, 2010 | Roper REX4634KQ Electric Dryer
Roper Dryer will not heat
I don't have a picture of the rear panel available, but if you have to remove the exhaust duct to remove the panel, I would be checking to ensure the exhaust ducting is not clogged/restricted. The duct does not have to be completely blocked to cause the dryer not to heat properly.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 19, 2009 | Roper REX4634KQ Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Roper dryer - no heat
You may have a bad fuse or t-stat but and I am not trying to be funny have you checked the circuit breakers? It takes two to make an electric dryer operate one makes it run the other makes it heat.
Dec 30, 2008 | Roper REX4634KQ Electric Dryer
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
NO HEAT
CK IF YOU HAVE 220V COMMING IN OR THE HEATING ELEMENT IS GOOD. OR CK THE THM FUSE.IS NO GOOD. BUT IF DRYER RAN OVER NIGHT AND DIDNOT TRUN OFF YOU HAVE TIMER PROBLUM. THE DRYER SHULD TRUN OFF EVEN YOU HAVE HEAT IN THE DRYER OR NOT.
May 03, 2008 | Roper REX4634KQ Electric Dryer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Roper REX3614KW Electric Dryer Logo
555 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
