Question about Motorola Mobility RAZR V3
CAN'T OPEN PHONE BOOK
I ACCIDENTALLY SAVED A NUMBER WITHOUT ADDING A NAME TO IT. NOW I CAN'T USE MY PHONE BOOK, IT FLICKS ON FOR A SECOND AND THEN TURNS OFF. I HAVE DONE THIS ONCE BEFORE AND THERE IS A CODE OR SEQUENCE OF KEYS TO PRESS, BUT I HAVE FORGOTTEN HOW TO DO IT.
  • GINGUNYAH Mar 07, 2008
    FIXED IT. .. Press 1# and scroll through phone book until you see a number without a name attached to it. Then either add a name or delete the number..... problem solved
  • 133 Answers
Please try removing the battery and putting it back again sorry i don't know of any code but will get back if i find one
Posted on Mar 07, 2008
How do I save phone numbers in the phone book. Nothing mentioned in instructions on how to finish the entering of numbers.
adding phone book entries
with the phone in standby mode, open the phone book
press menu/select and select create new
enter a name and number
enter the phone number ( up to 20 digits exactly as you would dial it )
if you need the phone to wait before sending the next of digits press redial/pause to insert a2 second pause
You can insert multiple pauses , but each one counts as a digit ( you will see P in the display)
the save mode is the menu button after each entry
Aug 06, 2017 | Cell Phones
I have just purchased a DECT3035 and am having difficulty putting in phone book entries
Hi
Adding Phonebook Entries
With the phone in standby, open the phonebook. Press Menu/se lect and select Create New. Enter a name & number and select a personal ring.Enter the phone number (up to 20 digits) exactly as you would dial ♦♦ l it.♦♦If you need the phone to wait before sending the next set of digits,press Re dial/pause to insert a 2-second pause. You can insert multiple pauses, but each one counts as a digit (you'll see P in the display).
More information read the manual
Jun 22, 2011 | Cell Phones
Numbers not names
Hi
Just check in the phone book whether the number saved in the phone book or sim card or momory card are saved twice with 2 different or same name. if it is saved with 2 different name/same name. nokia phone gets confused which name to be displayed and he flash only the mobile number and not the name.
Mar 02, 2010 | Nokia E63 Cell Phone
Contact Number
Hi, You can import phone data from a Subscriber Identity Module (SIM) card to the address book application on your BlackBerry smartphone.
Contacts in the address book can be saved to the SIM card individually. You cannot import data from the address book to the SIM card.
To import a single contact, complete the following steps:
1)On the BlackBerry smartphone Home screen, open the Address Book.
2) Display the menu and select SIM Phone Book. The SIM phone book is loaded.
3) Select the contact you want to import, then select Add to Address Book.
4) In the New Address screen, add any additional information.
Import all contacts, complete the following steps:
1) On the BlackBerry smartphone Home screen, open the Address Book.
3) Display the menu and select Copy All To Address Book.
4) Go back to the Address Book and make sure all the entries are displayed.
After adding information to ddress book you can able to veiw contact list, I hope this information will be helpfull.
Oct 14, 2009 | RIM BlackBerry Bold 9000 Smartphone
Is there any way to make the persons name appear for a text
It should be as simple as adding their name and number to the address book on the phone.
Make sure to list the number under the Mobile Phone line.
While in the address book, there is usually a line that says "New Entry" or "Add number" etc...(without the type of phone I cant get specific).
Another method is to into the text message itself and do an options click (again without the phone cant be specific) and there should be an option to add the number to the address book.
Aug 05, 2009 | Cell Phones
When receiving a call, only the number comes up on screen.
probably u saved this number before without a name search your unnamed contacts and delete the entry
Feb 05, 2009 | Nokia 5800 XpressMusic Smartphone
Caller ID function of Samsung i900 not working properly
you could try adding a + in front of the country code. (Ie for the USA it would be +1 999 555 1212
Apr 09, 2017 | Verizon Communications Samsung FlipShot...
Phonebook
If you tell you phone company, they would most likely replace your phone for free if you tell them that its defective. T-mobile does it for sure. Hope I helped. =)
Feb 24, 2008 | Motorola Mobility RAZR V3
V3 Phone book
Press 1# then find the number without a name and either edit or delete it
Nov 06, 2007 | Motorola Mobility RAZR V3
Phonebook access
i can help... i have incurred this problem a couple of times and understand the frustration! firstly, the reason why snd how this problem occurs is you have saved a number to your phonebook without a name and this causes the phone book to wig-out! to fix the issue simply press "1#". This will allow you to view your phone book in its speed dial order. Scroll through this menu until you find the saved number without the name and DELETE it. This will immediately bring your phone book back to normal. Good luck!
Dec 22, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
