I don't know how to set the presets or actually any of the settings on me 684xlr peavey sound mixer. I know they can vary, But I need to know where to start....Thank You
  • kjbeasley Mar 07, 2008
    I am talking about time/size , color time,
    and reverb presets. where do I set them to start.
    I need to know where to start with the presets dial, the time/size, color, and reverbs.
  • 818 Answers
Start here from the manual
http://www.peavey.com/media/pdf/manuals/xr684_684plus.pdf
Posted on Mar 07, 2008
  • 492 Answers
Always best to start at the middle. You want to use music through it that you know and perhaps have heard recently at a concert. Center all the sliders and adjust them independently to create a natural sound starting with the mid range then the highs, then the lows.
I want to use theMackie as a sub mixer into a powered "all in one" Peavy mixer, where do I come out of the Mackie into one of my powered mixer line inputs?
Take the main outputs into a stereo input (or a pair of mono inputs) on the Peavey - without knowing which Peavey I cannot tell you further info re set-up but as you'll be sending line level signal you'll need to back off the gain on the channels you input to on the Peavey
Nov 17, 2016 | Mackie Music
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
How do i set up a Peavey xr560 mixer and graphic equalizer
PUT OUT PUT EQUALISER IN INPUT RETURN PUT IN PUT EQUALISER TO OUTPUT MIXER
OR JUST PUT EQUALISER BETWEEN MIXER AND AMPLIFIER MEAN OUT PUT EQALISER TO IN PUT AMPLIFIER AND INPUT OF MIXER TO OUT PUT OF MIXER
Oct 12, 2014 | Peavey Audio Players & Recorders
Setting up pv20 usb
http://www.peavey.com/products/index.cfm/item/699/116338/PV%26nbsp%3B20%26nbsp%3BUSB
Look under "Downloads" tab at bottom for owners manual info. In a nutshell...mic to mixer channel #1, mixer connected to power amplifier, amplifier connected to speakers. Start with zero volumes on all equipment, bring up amps 1st (1/2 volume) and then adjust mixer until sound is heard from the microphone.
Oct 31, 2012 | Peavey Music
I can`t get any sound from my pv8 mixer i put the speaker cable i have put the red & white phonos into the mixer from my laptop getting on sound from the clip at all please can you tell me where i am...
Several things to do: Plugging into the tape type inputs... say the 7/8 channel.
The little button below the set you plug into needs to be pushed to the down position. This selects the "B" set which are the RCA jacks.
Below the set you are plugged into. Turn up the top knob "Gain" until the "clip" LED just isn't quite flashing.
At the bottom of that same column Turn up the "level" as needed for the mix.
Then of course, advance the Master level as needed.
May 13, 2011 | Peavey Electronics Peavey Pv8 6-input...
When using my peavey mixer XR212 in a live musical duo over the past 8 weeks of using it bought new we are getting a loud high pitched hissing sound when we sing loudly.We assume this may be the reverb...
Hi, most times when you use a mixer for too long and don't service it or take it to be serviced,itmight one day develop a fault by it self..
If i may ask,when have you taking it for servicing? If never,please do..
Sometimes dust entering into a mixer can make it malfunction.....
Since you know how to use the mixer properly,you don't have problem with that ok, Just take itto a repair man for servicing and he might tell you if something else is wrong with it after servicing it..
Take care..
May 05, 2011 | Peavey XR 1212 Powered Mixer Mixer Powered
My husband purchased one of your xr8600 peavey mixer the problem hes having is he cant get the echo settings right.please can you help.
View videos on YouTube regarding "mixer setup". Find the parts of setting up of "effects". Don't worry that you have a different mixer, the principles are all the same for analog mixers. Steps are this: Set the EFX send level for EACH of the input channels (knob above each channel gain) for the proportion you want for each channel. Check that the level you are sending does NOT cause the effect clip light to light very much. Set the effect you want, delay, echo, etc. with the selector knob. Advance the output sent to the power amp with the two knobs in the upper right of the panel. Adjust the "time" knob for the delay or effect depth you want. Then go over the same settings in the same order until you get the sound you want.
Apr 24, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Hi, I would to say thanks a lots to let put some words on yours email box. It's just regarding about how to set up a live band gigs @ outdoor stage in to mixer system. In a mixer setting, i wana know how...
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:http://mixonline.com/live/FixIts/, http://en.wikipedia.org/wiki/Live_sound_mixing, http://mixinglivesound.com/blog/tag/outdoor-concerts/,http://mixinglivesound.com/blog/, and http://www.scribd.com/doc/11435651/Beginners-Guide-to-Mixing-Sound. You may need more monitors than you are planning on and you might consider in ear monitoring.
Aug 22, 2010 | Music
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Jun 12, 2010 | Peavey Pv 2600 Power Amplifier
57 people viewed this question
 Grubhead
Grubhead
